Team Associated B74 4wd buggy >
Like Tree172Likes
    Hide Wikipost
Old 08-14-2019, 10:03 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B74 4wd buggy
Last edit by: mes
B74 Manual
New parts list
Product page
petitrc set-up page
Pistons explained
B64 carry-over parts:
- front and rear wheels
- springs
- pistons
- plastic diff gears
- shock caps
- spring cups
- arm mount inserts
- ball cups
- wing
- clamping wheel hexes
- generic hardware, tools, fluids
Fan mounts:
Revolution Design Yokomo YZ-4SF Aluminium Fan Mount RDRP0474
Schelle B74 Fan Mount and Wire Clip SCH1444 (SCH1444-COMBO with Motiv fan)
Revolution Design B74 Fan Mount RDRP0495
Aluminum options:
front shock tower RDRP0496
rear shock tower RDRP0497
rear hub set RDRP0489
Gear chart:
Print Wikipost
Old 08-05-2019, 11:16 AM
  #511
Default Sneak peek
Wholeshot28 is offline
Old 08-05-2019, 12:36 PM
  #512
What did you use to color the edges?
Di_spencer is offline
Old 08-06-2019, 08:52 AM
  #513
A sakura paint marker.. while its not completey dry you can just use your fingernail to scrape it off the gloss and make it a clean edge. Any good branded marker should be okay. And if you really wanted to make it worth it ..do a final coat of "clear" with CA glue. To make it gloss edge (test it to see if it reacts negatively with the paint first) ..this edge in the photo is matte. So far it holds up pretty well if it gets knicked or scratched I just touch it up.
Back the day... (lol early 90's) I rememberd in a rc car action magazine they would do a pro drivers "under the hood" and like show off little tricks and mods. Colored wires.. annodized stuff...etc. well someone did this! I remember the first I saw the edges were painted white..I wish I could remember drivers name...
yall feel free to go for it !
071crazy and xfbaap like this.
Old 08-07-2019, 05:26 PM
  #514
Default I like a clean set up too.
Originally Posted by JeepnMike View Post
Just a kudo to mes here. The YZ-4SF fan mount really looks like it was made for this chassis (I just installed one too). The fan fits flush with the bottom of the chassis (no washers needed), the bracket that attaches to the chassis brace fits perfect, it is just right all-around. I am weird and like my installs to look overly-tidy, this helps a ton - thanks for the tip.
I bought the Schelle plastic one and the plastic cracked before the screw even got snug. I ordered the ya-4sf one now. Thanks for the tips.
JeepnMike likes this.
DDavidge is offline
Old 08-11-2019, 09:16 AM
  #515
xfbaap's Avatar
Has anyone tried to fit a b74 body on a b64 or vice versa? I know the rc8b3.1 body will fit the rc8.2 buggy with some extra trimming. Wondering if this would work for the 1/10 predecessors. Cheers 🤘
xfbaap is offline
Old 08-11-2019, 10:38 AM
  #516
lbckevin's Avatar
Trader Rating: 96 (99%+)
The B64 body will fit with some trimming on the front. I ran it for a couple weeks until I could get the new body painted. I mainly cut the front to clear the steering and the front corners.
xfbaap likes this.
lbckevin is offline
Old 08-11-2019, 12:03 PM
  #517
xfbaap's Avatar
thanks for the reply 🤘 where exactly did you have to trim?
xfbaap is offline
Old 08-11-2019, 12:17 PM
  #518
mes
You are very welcome!
IIRC I saw a dedicated, as yet unreleased RDRP B74 fan mount in a picture of Sven Rudig'sor Joona Haatanen's car at the Euros somewhere. Let me see if I can find it...
Edit: Here you go! It is Joona Haatanen on circusrc.com
mes is offline
Old 08-12-2019, 05:17 AM
  #519
Default B64 diff washer size
Iíve been trying to get the b64 diffwashers due to the coning issue but in the Uk everywhere is out of stock. The part number for the b74 shim is only for a complete gear set including washers so is an expensive way to get the washers
does anyone know what size the b64 washer is or have an alternative that will fit?
losi8lunie is offline
Old 08-12-2019, 08:52 AM
  #520
imprsme's Avatar
Trader Rating: 80 (99%+)
imprsme is offline
Old 08-13-2019, 05:02 AM
  #521
Which washers are you actually looking for, the blue ones people are using instead of the large ones behind the pin?
If so I believe the importer stock has been depleted and they are waiting for fresh stocks to be shipped from AE.
As an alternative I've been using the Core RC CR451 5 x 8 x 0.1 shims in mine, 2 shims each side as the original kit shim is 0.2mm thick. Been working perfectly for a while now, 10 in a pack for about £2
John Myall likes this.
RogerM is offline
Old 08-13-2019, 05:36 AM
  #522
cheers Roger (should have asked you on Sunday &#128540
ill get some ordered.
Old 08-14-2019, 04:05 AM
  #523
Most people who spoke to me on Sunday wish they hadn't .... we all get those meetings where luck is definitely not on your side but Sunday was just a disaster!
losi8lunie likes this.
RogerM is offline
Old 08-14-2019, 09:58 AM
  #524
mes
Just added various RDRP parts to the wiki:
Source: https://www.ruddog.eu/Neuheiten-08-2019
mes is offline
Old 08-14-2019, 06:44 PM
  #525
jonski's Avatar
Trader Rating: 282 (99%+)
Darkside Designs battery oring strap is awesome!
lbckevin likes this.
jonski is offline
