Kyosho Lazer ZX7 Thread >
Like Tree15Likes
Old 04-16-2019, 02:24 AM
  #16
Originally Posted by fattire View Post
very weak front end can't keep the steering arms or the bearing hubs from breaking, even on mild jumps on our clay track.Hopefully someone comes out with a fix...
​​​​​​ Kyosho have recognised that these are weak and there is now an updated version in the shops, part number LA387B (The B designates an updated part) The Exotek parts are only available in 10 degrees so it depends on your setup as to if you could run these.
M.Boos is offline
Old 04-16-2019, 07:45 PM
  #17
fattire's Avatar
so the exotek c hubs will work with zx7 arms ?
fattire is offline
Old 04-17-2019, 02:28 AM
  #18
Yes, I have them mounted...
M.Boos is offline
Old 04-17-2019, 08:36 AM
  #19
fattire's Avatar
thank you for your knowledge sir,I will give these options a try
fattire is offline
Old 05-30-2019, 12:07 PM
  #20
Can't wait to give my new ZX7 a few laps this weekend! I'll add a pic when the forum allows, it wouldn't allow me to add it.
KeefeinVA is offline
Old 05-31-2019, 05:56 AM
  #21
You will love it...I'm doing some clubracing this weekend,too.
M.Boos is offline
Old 06-29-2019, 10:01 AM
  #22
I noticed a pic of jelins zx7 with the servo swapped to the right side of the car. Is anyone running there servos like that or stock? What would this do?
performance26 is offline
Old 06-29-2019, 10:25 AM
  #23
I run it that way, too...it's easier to place the wires from the speedo to the motor, IMO.
M.Boos is offline
Old 06-29-2019, 10:32 AM
  #24
Ive set mine up that way and agree the wiring is a lot better
Old 07-12-2019, 09:17 PM
  #25
Is anyone running the center diff in the zx7? If so what diff oil are yall running?
Old 07-19-2019, 06:37 AM
  #26
Anyone else having the problem with the front and rear universal swing shafts start binding after a few packs and not moving free anymore? It seems like the pin is moving against the collar and starts causing the binding...After removing the collar and putting the pin back in it's position the universals move free again. It doesn't matter if I run them with grease or without...
I don't have that problem with the same universals in my RB7.
M.Boos is offline
Old 07-21-2019, 07:30 AM
  #27
For those who are interested...
I just left away the set screw that secures the pin and now it's all good.
M.Boos is offline
Old 09-07-2019, 11:58 AM
  #28
So with the worlds just around the corner does anyone know if there is anything new going on with the ZX7?
Chrissy Boy is offline
Old 09-07-2019, 04:32 PM
  #29
I’m considering ordering this for indoor carpet. Should I wait until after the worlds or any reason why not to pull the trigger on this now?
22dasher is offline
Old 09-09-2019, 01:56 AM
  #30
Originally Posted by 22dasher View Post
Im considering ordering this for indoor carpet. Should I wait until after the worlds or any reason why not to pull the trigger on this now?
I doubt that we will see something completly new at the worlds...
M.Boos is offline
