Running front springs in rear on buggy
Hey, so I only race on carpet, which means my ride height is low - 16mm. Last night I put a spare set of springs that I had for the front, on the back. The back ones I couldn't adjust below 18mm. And sure enough, I can get adjustment around 15-18mm, which is what I want.
Assuming the rating of the springs is the same, should I expect to feel a difference? Has anyone done this before?
Front springs are much stiffer than rear. It can be done but if you were to put say an associated red v2 (kit spring on b6.1) on the rear that is almost 2x stiffer than the rear v2 blue. (4.6 to 2.85). Xray makes some springs that are shorter (57mm rear) that work well to get low ride height. The other option is to cut the spring but only do that if you have to - never plan on needing taller again.
Why can't you get below 18mm? Are you using the shortest spring cup and raised axles?
It's on my 22 4.0. Yes, smallest cups and shock ends.
I guess my question is this. I see a lot of setups with AE v2 Gray rear shocks. They are 2.2#/in. I would like to try that setup. I have that sleeve of springs that TLR sells and the front pink ones in there are rated for 2.3#/in. I put it in last night and I can get my ride height correct.
So my question is....this spring should behave almost like the AE gray rear that I see on a lot of setups for carpet on the rear.
Are you sure it “works”? A front spring is too short for a rear shock’s stroke length. If you’re reaching the desired low ride height, I can’t see how the spring is long enough to extend the shock to its full length. The spring would also be much more progressive, making it too stiff at the end of the stroke. If you’re limiting your rear shock stroke a lot, that might be different.
I've seen this problem with the TEKNO EB410 ran on turf, the platform was designed to run on dirt tracks but there are aftermarket upgrades from Vision Racing Products to increase the height of the shock towers to still use stock shock parts and get lower ride height in the 12-14mm range. Many different ways to get good performing setups for high traction carpet and turf
To billdelong's point above, one relatively easy change could be to use the B6.1"D" rear shock tower, which is sized for the longer rear shocks. Then you could couple it with long eyelets and the shorter length shocks and maybe get to the desired ride height while still having all of your travel sprung.
A few things you could do . 1 put some spacers under the tower to raise it up . I saw this done a while back on a losi team drivers setup . basically making the tower taller lowering the ride height 2 is put rear hubs made for a b6.1 on it . you probably will find running the ride height as low as you are that the rear bones are not level at ride height . The AE style hubs have adjustment to fix this losi hubs do not .
Oops, I forgot you're running the TLR so obviously my shock tower suggestion is out..
Which rear hubs are you running? If you are using the dirt hubs instead of carpet hubs you will not be able to get down to the ride height you want. If you are running and can't seem to get the ride height to take a set look into bleeding the rear shocks. They build pressure and make the ride height creep. You can also put shims under the rear shock tower to lower ride. Instead of front springs, spend the money on carpet springs from Yokomo. They are shorter and the appropriate rates.
What setup do you run?
I like to try different stuff, so I really wanted to see what would happened. I wouldn't hesitate to suggest for someone to try it on a track similar to mine (smaller with a good amount of jumps, the biggest one being a double 8 feet long).
I thought I could get there by jacking up the rear tower, but that would raise the CG. The shorter springs lowered the CG a bit. I didn't know they had different hubs, I'll check it out tonight. But doubt I'll change the springs, I really like the feel of the car.
This is really similar to my setup. I changed the trail setting on the front, and run a little shorter wheelbase. http://site.petitrc.com/setup/losi/S...d_SCVRC201804/
Is it a must for the rear bones to be level? Whats the downfall?
I'm new to this if you guys can't tell!
did your setup work. thats about it .yes or not so much. if it did run it. used oddball springs in other rc on carpet.
