Off-Road Chassis Balance Scaling >
Like Tree9Likes
  • 1 Post By trf211
  • 1 Post By chuck_thehammer
  • 2 Post By a1
  • 3 Post By Anthony.L
  • 1 Post By Robbob
  • 1 Post By Racer56556
Old 01-18-2019, 12:03 PM
ChappyEight's Avatar
Default Off-Road Chassis Balance Scaling
I know that the on-road guys spend lots of time balancing their chassis using scales for corner weights and front-to-back. Is that something commonly done in the off-road arena (buggies, truggies, e-buggy, etc.)?
ChappyEight is offline
Old 01-18-2019, 12:26 PM
Is it common? Not really. Can it help fix odd handling characteristics? Absolutely. If you are serious about setup it will be another helpful tool to zone in on the perfect setup.
ChappyEight likes this.
trf211 is offline
Old 01-18-2019, 04:37 PM
as already stated....... NOT COMMON.. but if you have problems.. it helps
but good detail to your car suspension is very helpful..
all moveable parts move evenly.. shocks build correctly...
I never needed to use scales. carpet, blacktop, dirt.
chuck_thehammer is offline
Old 01-18-2019, 08:13 PM
a1
NOT COMMON, but IMO SHOULD BE COMMON. I dont think you could ever go wrong looking for a balanced chassis.
ChappyEight and Sir 51D3WAYS like this.
a1 is offline
Old 01-18-2019, 08:25 PM
Anthony.L's Avatar
Trader Rating: 36 (100%+)
It can be a thing...
ChappyEight, Sir 51D3WAYS and a1 like this.
Anthony.L is offline
Old 01-19-2019, 09:32 PM
a1
NICE!!!
a1 is offline
Old 01-19-2019, 10:26 PM
That setup there is cool, but that's just static balancing. You can have it balancing there, but shock collars all messed up giving you a messed up percentages
Racecarguy is offline
Old 01-20-2019, 02:41 AM
when you assembly your suspension...
a flat block with 400 grit sandpaper... make sure all parts fit and move correctly...
a scale does nothing for parts not working correctly..
shocks are a pain.. but very important to be assembled,, and oil added and bleed RIGHT.
if you want a race car.. then make sure it is built like a race car. . DETAIL is everything.
also.... after a few days of racing... disassemble the car... clean, check, oil every moving part.
you want to race.. then you must operate like a race 'team'.. all by yourself..
Old 01-20-2019, 02:54 AM
and the reason for 4 corner scales... real weight, on each wheel.
but at the end of the day.. its how the car handles... scales can not do that.
scales HELP to make a given setting repeatable. ( a good thing )
in the real world of racing... driver input for feel and control, suspension mechanics, engineers.
Old 01-20-2019, 03:21 AM
Sir 51D3WAYS's Avatar
Its something we should do but never. Prolly because the effects are much less noticeable in dirt. I still can't determine with any certainty whether or not my YZ4 is balanced.....
Sir 51D3WAYS is offline
Old 01-22-2019, 06:20 AM
gticlay's Avatar
Trader Rating: 14 (100%+)
Lots of people do this in both 1/10 and 1/8th. Just buy 4 digital kitchen scales when they are on sale and use those.
gticlay is offline
Old 01-22-2019, 10:31 AM
Interesting thoughts. I need to work on my driving before needing stuff like this, but coming from the real-life racing world (1:1) I was just curious if any off-road R/C racers used scales for corner weights, etc. Really appreciate all the insight.
Old 01-23-2019, 05:48 AM
Touring Car = important
Off road = Good way to set the car after rebuilding shocks or making major changes to the car at home. Better way to setup a balanced car before hitting the track and wondering if it could be wrong.
IMO not a priority but helpful when getting a baseline setup.
Robbob is offline
Old 01-23-2019, 11:07 AM
A friend of mine just picked up the sky rc scales . we got the left to right even at 50/50 even tho they were not to far off to begin with (49/51) . The most interesting thing is adding weight we noticed adding weight in different areas affected the chassis differently than you would think it would based on the placement . The nice thing was it confirmed what i was feeling on the track .
Racer56556 is offline
