TLR 8ight X-E
#769
i am using 15k, but did not see issues with the stock 12.5k....
#772
If per say you want the car to unload or have more rear bias on the rear then the rear differential should be lowered in Weight (cst) in comparison to both front or center.
#773
The more thick the center diff is, the more solid the center drives will be. Increasing the center without considering the front differential may actually cause the front spin faster due to the way centripetal force is applied.
#774
It may be a symptom of my having raced touring car a lot and never having raced anything with a center diff before. I see the car squat and the front tires go light, balloon up a bit, and it seems like a lot of wasted energy. I watched some videos of truggy racing and this seems par for the course.
#776
i run on an outdoor loose dirt track and put 10k in the center
#777
Fresh Paint
#779
is there a 8ight xte forum?
#780
anyone having issues with the emulsion shock seals? I just built them and 2 of the 4 shocks are leaking bad from the bleeder hole on the lower portion of the shock cap.
They do go tapered side down right?
I opened the shocks up and looks like they may of gotten seated incorrectly and are slightly warped.
