Like Tree33Likes
TLR 8ight X-E
Old 05-13-2019, 06:12 PM
  #301
nitro_mt_racer's Avatar
Trader Rating: 225 (100%+)
Originally Posted by Taman View Post
Is it worth getting the front and rear DE racing skid plates?
thanks
Are DE plates available? Last I looked they weren't. We bought Sumo plates for our cars.
nitro_mt_racer is offline
Old 05-13-2019, 07:28 PM
  #302
Taman's Avatar
Trader Rating: 66 (100%+)
Amain has them
Taman is offline
Old 05-13-2019, 08:07 PM
  #303
Panther6834's Avatar
Amain has them
Link ?
nitro_mt_racer likes this.
Panther6834 is offline
Old 05-13-2019, 08:09 PM
  #304
Amain has them
Got a link? Don't see anything on Amain or DE's website that says it fits the X.
Old 05-13-2019, 08:35 PM
  #305
Taman's Avatar
They don’t say x specific - is there that much difference between the chassis?
just went to the sumo site and it says the x uses different plates. So these won’t work.
https://www.amainhobbies.com/de-raci...-210-l/p168912
Taman is offline
Old 05-13-2019, 08:37 PM
  #306
Not sure if the hole location is the same or not. I don't have any of my 3.0/4.0 stuff left to compare it to.
Old 05-13-2019, 08:38 PM
  #307
Taman's Avatar
I emailed DE this morning so I’ll let you know when they get back to me
Taman is offline
Old 05-15-2019, 06:59 PM
  #308
dickie doyle's Avatar
just finished building a 8ight-XE, the Protek servo and TLR aluminum servo horn Iím running kicks the drag link at a silly angle (up toward the back). Is it important to get that link as level as possible?
dickie doyle is offline
Old 05-18-2019, 10:40 AM
  #309
Mark98SS's Avatar
Default Noob question
The allen set screws in the control arms close to the chassis appear to be travel limiters. I don't see anything about them in the set up sheet so how do these get adjusted?
Mark98SS is offline
Old 05-19-2019, 02:13 AM
  #310
Trader Rating: 76 (100%+)
I'd say yes, only from experience. I needed to ship my link 2mm down on the servo horn side. When it was raised , it would have a very bad bind issue when steering was turned to steering lock. Once shimmed, the bind was gone, and now had lo actual lock to lock steering with ZERO bind. I hope this helps.
Raul Garcia is offline
Old 05-19-2019, 08:01 AM
  #311
Those are Droop Screws. In the most basic form, they will set your installed shock length and angles of the arms while there is zero weight on the wheels. Iím not sure how people are setting the overall shock length as per the setup sheet, but this adjustment would change the shock length once they are installed.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
