Like Tree38Likes
TLR 8ight X-E
Old 01-05-2019, 10:33 PM
  #16
Trader Rating: 19 (100%+)
Originally Posted by TlrLosi210 View Post
That is a strange looking motor. Not sure I'd want to let that much dirt in...
MX304 is offline
Old 01-06-2019, 09:07 AM
  #17
Spads11's Avatar
Trader Rating: 30 (100%+)
I would guess that the motor would be for indoors (clay) only. I have never seen anything like that before though.
Spads11 is offline
Old 01-06-2019, 01:12 PM
  #18
From TLR Facebook:
More? Split center diff mounts for easy access and maintenance !
TlrLosi210 likes this.
Evoking1230 is offline
Old 01-07-2019, 07:48 AM
  #19
TlrLosi210 is offline
Old 01-07-2019, 11:53 AM
  #20
ta_man's Avatar
Trader Rating: 154 (100%+)
Looks like they either did away with the ability to choose to cant the diff/motor to match the center drive dogbone angles.
(Or did something different to address that.)
ta_man is offline
Old 01-07-2019, 12:04 PM
  #21
On the 8X the front gearbox was changed so that the angle on the front and rear drive shafts are the same. So I would assume the 8XE would use the same gearboxes as the nitro so there would be no need to angle the motor anymore.
fantomdude is offline
Old 01-07-2019, 02:48 PM
  #22
you forgot to add the caption
Want to run an electric clutch? Flip the center diff around and don't worry about fitment issues
or something along those lines :-P
Old 01-08-2019, 08:41 AM
  #23
What you guys think about electric clutches, i have one for my 4.0 and didn't like it. I want to put it back on and give it another try.
Old 01-08-2019, 12:41 PM
  #24
Furadi's Avatar
I feel like it's a solution to a problem that doesn't exist. I tuned the throttle in my buggy with punch control settings and throttle end points in the radio.
Evoking1230 likes this.
Furadi is offline
Old 01-08-2019, 03:10 PM
  #25
This.
I believe Drake used to run a clutch setup on his TLR or was it MBX7 eco? I forget.
EDIT: wOOt! wOOt! 1,000th post!!!
Old 01-08-2019, 05:47 PM
  #26
Originally Posted by Evoking1230 View Post
This.
Drake has run the clutch on pretty much every e-buggy and e-truggy he has ever driven. Still using it on the MBX8 and MBX8T.
MX304 is offline
Old 01-08-2019, 07:53 PM
  #27
See, wasn't too far off 😆
Old 01-09-2019, 10:47 AM
  #28
This.
yea he uses the tekno e clutch on Mugen I think with Mugen shoes and bell if I remember right. I know he has it on his YouTube.
jersey is offline
Old 01-09-2019, 01:01 PM
  #29
stupid question, for the velcro....is everyone using a specific special strength one or just gluing it to the sides of the chassis and inside of the body?
Old 01-09-2019, 02:28 PM
  #30
are you referring to the body , if so I just use the pins and it holds up well. But I do use one sided velcro on my 22, i use team associated Velcro. Holds up well
