Pins for dog bones
#32
Instead of needing a tool you can drill the hole in the bone big enough that the pin is a slide in fit and then solder the pins in place. Works fine unless you have aluminum dogbones. I've never had a soldered-in pin come loose and when it is time for replacement, the job is easy.
#34
Review/how-to of the RCrenew tool:
#35
Good lord, that is a PITA tool to use.
I will need to make a video using the Hudy one.
But good review nonetheless. Keep up the good work.
#36
Video is ok... but in reality I can do a pin replace in less than a minute.... very simple and quick once you learn how.
The 'Yellow Jacket' wrench shown at the start of the video is the secret, and I took an old open end 3/4 wrench and cut it down to about 4"
#37
And I too jamb'd a 2.5 pin trying to force into a dog bone. It felt too tight and I gave it another 1/2 turn LOL
Sent back to RCrenew and he explained to me not all pins are created equal and suggested I use an RC product. He un-jamb'd the tool and sent it back to me .... no charge. Great customer service.
#39
Grab a measuring caliper, measure width and length. Then off to the races finding them. But one of the ebay link posted above should work.
#40
https://www.rcrenew.com/tools.html
l
#41
FWIW, I have made pins from the shafts of metric hex drivers in a pinch. They are hardened steel (usually) and come in common useable diameters. Use a Dremel cut-off wheel to cut to length and the chamfer the ends with the side of the cut off disk. Be sure to wear safety glasses when using a Dremel cut-off disc. They will shatter and scatter-especially when using them as a flat grinding surface.
AC
AC
#42
AC
AC
#43
I bought these off Amazon and just finished replacing the pins on my EB410. They are definitely hard enough to work, seem good so far. Next question will be if they are too hard, we shall see. They are rated GCR15 steel, which I think is a Chinese classification.
https://amzn.to/2mMxmY6
#44
a little ambiguous on which car you need pins for, sounds like you want 2.5x10mm pins for the B6?
l
l
#45
Rezzing this thread to mention Motion Pro
One of the best pin remover, chain breaker, and riveter I have used is made by Motion Pro #08-0058 buy from denniskirk.com
And loctite 609 bearing mount and retainer adhesive or 271 red if 6xx loctite is hard to find.
Absolutely no issues..
