Old 02-24-2006, 03:38 PM   #1
mkimmer's Avatar
Send a message via AIM to mkimmer Send a message via Yahoo to mkimmer
Default Help with Nitro Evader ST Idle
I am wondering if I have my idle set too high or too low on my Duratrax Nitro Evader ST. Below is a short video of it. LMK what you guys think. Thanks.
http://www.zippyvideos.com/8925759013949056/100_0763/
mkimmer is offline   Reply With Quote
Old 02-24-2006, 04:26 PM   #2
Trader Rating: 14 (100%+)
it sounded good but you still need to make a couple small adjustments.
An engine should idle at a noticiably lower rpm after 5-7 seconds of idling. This is caused by the engine "loading up" - too much fuel coming into the engine. This will eventually cause it to stall after another 5 or so seconds.
What you need to do is turn in your idle screw by an 1/8 of a turn and then richen your low speed needle about an 1/8 of a turn. Don't be afraid to make adjustments, it is how you learn. It is alright if the engine runs lean for a minute or two so don't worry about that. Don't make any adjusments more than an 1/8 of a turn at a time.
o.s. power is offline   Reply With Quote
Old 02-24-2006, 05:23 PM   #3
mkimmer's Avatar
Which way do I turn the idle screw? Clockwise or counter clockwise? Thanks for your info. It just seems to idle faster, then start idling slower alot.
Old 02-24-2006, 09:35 PM   #4
to raise the idle like I said - turn the idle screw clockwise. When it idles higher, does the truck move under its own power?
Remember just make small adjustments - 1/8 turn at a time, once you set the idle screw don't touch it - this screw is rarely adjusted once you get your truck to idle properly.
Weather plays a huge role too, any significant temp differences will make huge differences in how the motor runs and idles. Example - you tune your truck to run in 40 degree temps it will run really good, but if you take those same carb settings and run your truck on a 70 degree day, it will be too lean and it will run like crap.
Old 02-25-2006, 04:18 AM   #5
mkimmer's Avatar
Yes, the truck will start moving by itself when it idles higher. Thanks for all your help. I appreciate it. I am playing with the settings. I almost have it where it needs to be.
Old 02-25-2006, 09:48 AM   #6
you don't want the truck to move under its own power.
But so far it seems you are getting the hang of everything. Remember to make small adjustments. I have some good tuning articles that you should keep - pm me w/ your email if you want them.
Old 02-25-2006, 01:39 PM   #7
mkimmer's Avatar
I pmed you. Thanks
Nitro evader BX FS Cannibalcorpse R/C Items: For Sale/Trade 4 04-14-2008 12:06 PM
rc10gt, idle probs. new 2 nitro parisherj Electric Off-Road 3 02-27-2006 05:19 PM
Nitro buggy won't Idle dan_allen_1 Electric Off-Road 3 02-25-2006 01:55 PM
Duratrax Nitro Evader ST or HPI Nitro MT2?? SuperVF1 Electric Off-Road 4 01-12-2005 06:58 PM
Evader st nitro EVADER RACER Australian Racing 1 02-14-2004 10:20 PM
