Like Tree879Likes
TLR 22 5.0
Old 12-21-2019, 10:09 PM
  #1351
thirtydaZe's Avatar
Trader Rating: 39 (100%+)
Originally Posted by A_Locomotive
Has anyone swapped out the composite shock caps for aluminium? I need to rebuild one of my front shocks, the shaft snapped at the track today. Since I will have to rebuild them anyway i was wondering if this might be a worthwhile upgrade.
no issues with them in my experience.
Originally Posted by radman123
Anyone have tips on getting the screws into the plastics without tapping the holes? Iím struggling on some of these and donít want to strip the holes out. Thanks!
Havenít really experienced that, did you try using grease on the threads?
thirtydaZe is offline
Old 12-22-2019, 12:58 AM
  #1352
I have pretty good luck with black grease, or chapstick
TurnNBurn and zipperfoot like this.
meandeanr is offline
Old 12-22-2019, 05:52 AM
  #1353
tony montana's Avatar
Trader Rating: 76 (100%+)
agreed
tony montana is online now
Old 12-22-2019, 09:20 AM
  #1354
I used a drill when it came to the turnbuckles. I very carefully mounted the ball cup into my drill and used that. otherwise I wouldíve stripped the ball cups
I upgraded right away. I overtightened mine when I built it and they would weap. Switched to the alum and never had an issue since. I have heavy hands though
Trlmatt is offline
Old 12-22-2019, 10:00 AM
  #1355
Trader Rating: 17 (100%+)
Every kit Iíve ever had from multiple manufacturers has a problem with stripping the bleeder screw holes. HATE plastic shock caps!!
Trlmatt likes this.
MrLean is offline
Old 12-22-2019, 10:39 AM
  #1356
You know. That right there is a good enough reason for me. Haha I definitely semi stripped one of mine, has had slow leak since its first run. Just a shame the caps will get all fucked up since they are exposed and I am a terrible driver. Haha
A_Locomotive is offline
Old 12-22-2019, 10:59 AM
  #1357
Trader Rating: 43 (100%+)
Hey guys, most of the TLR elite owners I race here at Hot Rod Hobbies (wet dirt track) have this problem with the buggy when its ran factory setup( I gather this setup is for clay). The buggy hooks to the left or right when punching in throttle. Even in the straight it does that.... worse when you are turning. Any setup help would really be appreciated.
Phillip F is offline
Old 12-22-2019, 11:07 AM
  #1358
Trader Rating: 16 (100%+)
dcerven94 likes this.
zipperfoot is offline
Old 12-22-2019, 05:36 PM
  #1359
Trader Rating: 79 (99%+)
I found that the replacement caps were better than the originals. I hated the black aluminum caps, always damaged the cap oring, even with proper precautions to not do so. Plastic caps for me.
Trlmatt likes this.
Raul Garcia is offline
Old 12-22-2019, 05:57 PM
  #1360
that's a bummer, I just ordered the black aluminum ones. Will see how they do when i rebuild my front shocks.
Old 12-23-2019, 08:27 AM
  #1361
Frank are there any plans to just release a gear box with the quick diff change or will we have to wait for the release of a new vehicle?
zipperfoot and Phillip F like this.
ChadoSan is offline
Old 12-23-2019, 04:34 PM
  #1362
I use the Jason Synder (Short Course World) pro-tips of a crayon, works great! Stole one of my kid's extra black crayons and keep in my pit tools for builds.
Phugazi is offline
Old 12-23-2019, 07:20 PM
  #1363
STLNLST's Avatar
Trader Rating: 32 (100%+)
so youíre the reason all the tires in their drawings are green.....lol
RazorRC likes this.
STLNLST is offline
Old 12-23-2019, 07:36 PM
  #1364
Is there any difference between the elite aluminum steering and the aluminum link & crank for the AC? I was thinking I'd get some elite parts so I could run clay at some point.
dswear22 is offline
Old 12-23-2019, 08:41 PM
  #1365
First. Make sure your shocks are not bound up. Then remove them and the tires and ensure the suspension is completely free. Rotate the car so that the arms are horizontal and slowly tilt forward or backward. If one arm moves long before the other you'll have some work to do to free it up.
jlett21 is offline
