Like Tree833Likes
TLR 22 5.0
Old 12-12-2019, 03:54 PM
  #1321
rc10t4orange's Avatar
Trader Rating: 16 (100%+)
Originally Posted by ironzgti35
So many options and hop ups to choose from...going to be running an AC kit on gray carpet and long pile turf. Are there any highly recommended options to grab right out of the gate? Aluminum diff gears, brass, etc
I'm running an AC on black CRC. I like the brass electronic weight and front pivot. Running Proline Z3 Prism front and rear. What tires will your track allow you to run? What are other running. I based my setup off of a local racer and Frank Root's.
rc10t4orange is offline
Old 12-12-2019, 06:28 PM
  #1322
Kings Kid's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Frank Root
I will try to get something up, but it won't be this week. Maybe next week.
Thanks 😊
Kings Kid is offline
Old 12-13-2019, 05:43 PM
  #1323
Trader Rating: 17 (100%+)
Just picked up an ELITE kit to run on carpet, and want to run the following setup:
http://www.tlracing.com/ProdInfo/Fil...TU_09_2019.pdf
However, my LHS doesnít stock the pistons and they are on backorder online until Feb.
What shock oil or other changes should I use to compensate for using the kit pistons?
Also, Iím not going to buy the 68mm dog bones at this time, should I make another adjustment to compensate for using the 67mm bones?
MrLean is offline
Old 12-13-2019, 06:57 PM
  #1324
Originally Posted by MrLean
Also, I’m not going to buy the 68mm dog bones at this time, should I make another adjustment to compensate for using the 67mm bones?
CVD pin position will need to be in 1 or 2.
jmitchell is offline
Old 12-13-2019, 09:55 PM
  #1325
Johnoly99's Avatar
Just run the standard AC kit set up for springs and oil. Start with that set up for things like ride height and camber as well
MrLean likes this.
Johnoly99 is offline
Old 12-16-2019, 12:12 PM
  #1326
Are there optional hexís to give you the offset to run B6 wheels?
ChadoSan is offline
Old 12-16-2019, 01:53 PM
  #1327
pink_sleeve's Avatar
Trader Rating: 218 (100%+)
When you move the front 2 axle shims on the Elite to the outside B6 wheels then bolt on. Is this intentional? Or meant just as a tuning option to widen the front end?
pink_sleeve is offline
Old 12-16-2019, 02:41 PM
  #1328
TurnNBurn's Avatar
Itís meant as a tuning option when using the 22 wheels to fine tune track width - I suspect this may change a bit soon. I read somewhere that there was a new IFMAR rule to standardize/limit the offset allowed for wheels in the 2WD class at the Worlds, but they elected not to enforce it last minute. It is speculated that maybe this is a precursor to having ready-made handout wheels/tires for future events?
TurnNBurn is offline
Old 12-16-2019, 03:50 PM
  #1329
B6 wheels make the 22 too wide to be legal. In order to make B6 wheels work on the front of the 22 you would have to redesign the front suspension and steering geometry.
waitwhat is offline
Old 12-16-2019, 05:30 PM
  #1330
Trader Rating: 137 (98%+)
Cvd pin location what's the theory behind this.
ashxxx is offline
Old 12-16-2019, 06:16 PM
  #1331
Default Setup
Frank what do you think about your BK race setup for 21.5 ?
rbrownsr is offline
Old 12-16-2019, 07:58 PM
  #1332
it controls axle plunge, effecting how much bind is introduced into the system with suspension travel
dcerven94 is offline
Old 12-17-2019, 02:50 AM
  #1333
Trader Rating: 43 (100%+)
how do I lessen bumpsteer in my Elite?
Phillip F is offline
Old 12-17-2019, 09:16 AM
  #1334
Which direction is it steering? In under compression or out? If it toes out during compression remove outer ballstud shims on the steering link. If it toes in during compression add more shims to the outer steering ballstud.
Pistol123 likes this.
trf211 is offline
Old 12-17-2019, 09:23 AM
  #1335
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
B6 wheels don't fit regardless. It makes the car extremely too wide and throws all of the suspension geometry out of wack.
The lower the number, the more bone lock up.
I don't really change setups for stock vs. mod, so yes, it should be solid for 21.5.
Lower the steering spindle ball stud to reduce bump out, raise it to reduce bump in.
Phillip F and rbrownsr like this.
Frank Root is offline
