Like Tree886Likes
TLR 22 5.0
Old 12-02-2019, 10:08 AM
  #1276
Originally Posted by Frank Root
Both, two plates, and both redrilled to move forward and sit against my servo.
Frank, will there be a 3.0mm shock conversion kit for turning the 5.0 elite into carpet?
shark2288 is offline
Old 12-02-2019, 10:14 AM
  #1277
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
We don't have an "all in one" part number planned right now. Usually, conversion kits don't sell too well. The 3.5 conversion kit probably won't be around come the end of next year.
Frank Root is offline
Old 12-02-2019, 11:45 AM
  #1278
TurnNBurn's Avatar
Please forgive my ignorance if it was mentioned a few (or several) pages back... What does the 3.5 shaft do compared to the 3.0 again? The effect of more pack due to the additional volume taken up by the thicker shaft?
TurnNBurn is offline
Old 12-03-2019, 12:27 AM
  #1279
Ill trade you my 3.0s for your 3.5s. Been running my sr since end of October. Message me if interested...
Trlmatt is offline
Old 12-03-2019, 06:54 AM
  #1280
Does the elite come with 68mm or 67mm cvas?
Old 12-03-2019, 07:15 AM
  #1281
thirtydaZe's Avatar
Trader Rating: 39 (100%+)
ELITE comes with the 67's.
thirtydaZe is offline
  #1282
Chr1s's Avatar
Chr1s is offline
Old 12-03-2019, 06:04 PM
  #1283
slakr's Avatar
Trader Rating: 36 (100%+)
What size screw holds the electronics plate to the chassis?
slakr is offline
Old 12-03-2019, 06:10 PM
  #1284
Losi Chaser's Avatar
2.5mm x 4mm
slakr likes this.
Losi Chaser is offline
Old 12-03-2019, 06:16 PM
  #1285
slakr's Avatar
Originally Posted by Losi Chaser
2.5mm x 4mm
Thank you!
slakr is offline
Old 12-03-2019, 10:49 PM
  #1286
I run a 22 4.0 as a wet astro car. I've just broken a front spindle (TLR234074) and currently cannot source one from the UK (but have ordered a set from the US, due end Dec or Jan 2020!). Does anyone know if the 22 5.0 front spindle set will fit (TLR234106)?
Thank you.
rugmuncher is offline
Old 12-04-2019, 03:08 AM
  #1287
Johnoly99's Avatar
Thank you.
yes. The only difference is the steering link arms. The spindles and c blocks are the same just the steering arm insert you screw on Changed on the 5.0
Johnoly99 is offline
Old 12-04-2019, 03:49 AM
  #1288
Well that's made my day! So are you saying I just use the steering arm inserts from my 4.0 on the 5.0 spindles?
Thanks for taking the time to reply.
Old 12-04-2019, 03:51 AM
  #1289
Johnoly99's Avatar
yes they should work.
Old 12-04-2019, 04:31 AM
  #1290
Default Servo horn length?
Any know the length from center of arm at spline to center of ballstud? Have an 18.25 one on my servo now and wondering of its too long
Pooch692000 is offline
