Like Tree879Likes
TLR 22 5.0
Old 11-24-2019, 05:18 PM
  #1246
Trader Rating: 18 (100%+)
I was pitting with Tyler at beachline for the Florida indoor carpet championship and all of us tlr guys ran 80k in our diffs with 2 gears. It gave us more on-power steering. We even over heard some yokomo drivers were using 120k.
Roberto Falcon is offline
Old 11-28-2019, 02:45 PM
  #1247
Johnoly99's Avatar
Default VHA arms vs non
Anyone know what the difference between the VHA rear arms and the standard stiffizel arms are? Have a few sets on stiff arms for the 5.0s but had a fun little off angle jump onto the front stretch last week right into oncoming traffic that ended poorly for me, thankfully didnít break anyone else.
Johnoly99 is offline
Old 11-28-2019, 07:55 PM
  #1248
jag5508's Avatar
Trader Rating: 15 (100%+)
Does anyone know if this is the brass c block for the elite with the new pills Tlr334065?
jag5508 is offline
Old 11-29-2019, 05:22 AM
  #1249
slakr's Avatar
Trader Rating: 36 (100%+)
Yes, that is correct...
TLR334065 = brass C block for the new TLR Adjustable Pivot Set
TLR334053 = brass C block for the standard 5.0 pivots.
jag5508 likes this.
slakr is offline
Old 11-29-2019, 06:51 AM
  #1250
jag5508's Avatar
Thanks 👍
jag5508 is offline
Old 11-29-2019, 08:09 AM
  #1251
Just need to verify that I'm deciphering this Elite pill chart correctly. If I'm running the red outlined options, am I running 1 degree anti-squat and 3 degrees toe?
Phugazi is offline
Old 11-29-2019, 08:45 AM
  #1252
TurnNBurn's Avatar
Ouch, that looks nasty. I only have an Elite, but comparing photos of the two arms, it appears that the VHA version pushes the outer cross brace inward a few mm, likely to give a little extra room for easy travel of the rear VHA hub at its various height settings. I couldnít tell you if they are the same overall length or not, but even if they were, itís likely that you canít use the regular arm with the VHA hub. And well, I guess you know the difference between regular and SZL parts in general; the former flexes more, so just switching arm material can change your handling characteristics a bit; you might lose a little bite with the SZL arms.
TurnNBurn is offline
Old 11-29-2019, 07:37 PM
  #1253
Johnoly99's Avatar
that setting would give you 2 deg toe and 2 deg anti squat. 3/2 is the starting point centered for both c and d block. You can move just the c by the increments on the pills, or just the d block OR both for a combined movement.
Old 11-30-2019, 07:52 PM
  #1254
Trader Rating: 26 (100%+)
Originally Posted by pink_sleeve
I think you mean 8000 not 80000
No, 80,000
RandyJones is offline
Old 11-30-2019, 08:57 PM
  #1255
Trader Rating: 24 (100%+)
Just built 2 Elites for stock and mod. Coming from AE. Kit setup, high bite clay/slicks. Need more on power steering coming into the 180 turns. Was told taking out/reducing the front kick out shims would help. Kit is 3mm, a 2mm and a 1mm. Any other tips? Anti squat?
dogbone418 is offline
Old 11-30-2019, 09:38 PM
  #1256
pink_sleeve's Avatar
Trader Rating: 220 (100%+)
Trying to assemble my new gear diff and the pins do not slide through either outdrive.
pink_sleeve is offline
Old 12-01-2019, 04:26 AM
  #1257
I have the same problem.
aurell is offline
Old 12-01-2019, 05:19 AM
  #1258
Most of the team drivers are running 2mm. I would definitely switch it.
jmitchell is offline
Old 12-01-2019, 06:20 AM
  #1259
Johnoly99's Avatar
Default Metal diff gears for G2 diff
Guys with the metal gears for the new G2 diff. Careful as the pins that go they the outdrive to hold the gear in place are SHORTER for the metal gears than the ones you need to use with the plastic gears.
You say they wonít go thru the outdrive home at all? Or when itís in the housing you canít get it to line up? FYI, using calipers to measure small inside diameters less than 1Ē is Iím a irate, as the tips of the caliper are not round and perfectly on the centerline, so you canít use that pic as a baseline of measuring the ID of the hole within the tolerances of these parts
Old 12-01-2019, 09:01 AM
  #1260
They do not go through the outdrives at all. At first I thought it wasn’t lining up then I tried the to put the pins through without the outdrive in the diff cup and the hole is definitely smaller in the outdrive then the pin
