Like Tree806Likes
TLR 22 5.0
Old 10-29-2019, 06:57 PM
  #1141
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Originally Posted by A_Locomotive
Quick question for anyone who has tried both. When I built my 22 elite there was the option of installing or not installing a body clip post at the front of the car. I didn't realize the rest of the body was only held on with velcro. I am wondering, how well does the body stay in place with only velcro? I havent painted or trimmed my body yet. Is it woryh disassembling the front and pulling out the clip post and going with only velcro?
I use velcro on all my cars, never had a body come off.
Wildcat1971 is offline
Old 10-30-2019, 06:12 AM
  #1142
Yeah, you don't need the clip post. You'll have no issues using only velcro to keep the body on.
Phugazi is offline
Old 10-30-2019, 08:19 AM
  #1143
Sorry if I am in the wrong part of forum, new to this forum thing?
Thanks in advance for any help. Just getting back into rc racing, i have a Losi 22 2.0 mid motor.
Can someone tell me what sway bar set will work on this 2.0 mid motor?
rfine7666 is offline
Old 10-30-2019, 09:05 AM
  #1144
For the front of the car you can run a 22 4.0 or a 22sct front sway bar but for the rear in mid motor configuration you are going to have to get creative and make one. At least as far as I know there was not a rear sway bar until the 4.0. The 22 SCT had one for rear motor configuration.
fantomdude is offline
Old 10-30-2019, 01:36 PM
  #1145
azdakota97's Avatar
Velcro has always held solid for me. I would just suggest putting the pieces on the mud guards first and then sitting the body on to make sure that you get as much contact with the body in place as you can.
azdakota97 is offline
Old 10-30-2019, 11:14 PM
  #1146
mes
I prefer full-length velcro strips over the patches supplied with the kits. Maybe it is a relic from the days when we used to run on dusty tracks, but it works better for me.
azdakota97 likes this.
mes is offline
Old 10-31-2019, 11:01 AM
  #1147
azdakota97's Avatar
Yeah, mine is currently that way as well honestly. Old habits die hard. Lol.
Old 11-01-2019, 12:29 PM
  #1148
Default Trail
Can someone explain the different trail settings for the front end please? I have the 5.0AC and a 22T 4.0 and am still lost on the purpose. Is it just a wheelbase setting?
dswear22 is offline
Old 11-01-2019, 12:34 PM
  #1149
mes
Less trail gives you more direct/aggressive steering. On the B5M, virtually everybody only used the 4 mm trail setting and AE accordingly ditched the inserts. You might give 3 mm a try, but it may be a handful.
mes is offline
Old 11-01-2019, 02:09 PM
  #1150
TurnNBurn's Avatar
I just want to add (at least in the case of the 5.0) that in addition to trail, you can also adjust the Ackerman setting to control steering aggression. The end result in changing the steering tabs on the knuckles is the amount of the throw each provides (default AC kit setup is #5 - right in the middle)... so, you can try varying combinations of the two adjustments to control the feel of your steering.
TurnNBurn is offline
Old 11-02-2019, 10:33 AM
  #1151
Today is the day! My Elite is going to the track today for the first time!
azdakota97 and aaron2u like this.
A_Locomotive is offline
Old 11-02-2019, 10:42 AM
  #1152
Let us know how it drives with the kit setup
Losiracer12 is offline
Old 11-02-2019, 11:42 AM
  #1153
SCRAFAN's Avatar
Trader Rating: 20 (100%+)
Your rear tires will have more sidebite if you put them on the other direction. (switch left and right).
lbckevin and Trlmatt like this.
SCRAFAN is offline
Old 11-02-2019, 08:24 PM
  #1154
Well this is my first 2wd buggy since the RC10B2 so I am probably not the one to ask. Haha. But i really enjoyed how it drove out of the box, the sole thing I adjusted today was I dialed back the slipper a little. I plan on playing around more with adjustments on future trips.
That was like the second thing said to me at the track. Haha I swapped them immediately. Going to try running them the other way next time to get a feel for what exactly changes.
Old 11-02-2019, 09:48 PM
  #1155
Chr1s's Avatar
You cannot rotate indoor tires. The leading breaks in and gives you more traction. If you try them in the other direction after you already ran them this way. It will be worse. Next set run them in the opposite direction.
Chr1s is offline
