TLR 22 5.0
#1024
Anyway, the 8ight-X has it, and as fuzzy as the spy shot was, it LOOKS like the 22X-4 has it, With his increased design involvement now official, I have faith that Jr. will get it done.
#1025
#1026
Probably even less time. I pulled the tranny in mine to install a direct drive. But after seeing how easy it is to access the diffs on my B74, I have a B6.1 on the way. I also see the quick access diff as a benefit if you’re under the gun to make a change, because there’s less of a chance of not putting it back together correctly.
#1027
I personally think that it becomes a bigger deal for anyone running the car with the gear diff, where it becomes more of a tuning option. I also think that when it must be done, it’s not so much an issue of “oh, it’s just a few more screws” than it is a time saver. Imagine running multiple classes where you have less time to work on every vehicle. Not only is it a time saver, but it encourages you to change that diff oil, or maybe even change the diff height, if you are running the ball diff. If it doesn’t work, it’s definitely a lot of time saved setting it back... TL;DR versión, it encourages more experimentation with the buggy.
#1028
I run 2 classes regularly and just picked up a 22t 4.0 for bigger races. I was running my 22 4.0 at the time and a bearing started going out in the transmission on race day. I got it diagnosed and changed in between heats but it was quite frustrating. It didnt help I was sitting right next to a speaker that was turned up more than need be and if the announcer wasnt loud enough, there was a loud beep every time a car passed the loop.. I litarally finished the buggy outside on the hard pickup bed cover.. I guess I'm a gluten for punishment, all my 1/10 offroad are TLR and I replaced the 4.0 with the 5.0..lol
#1029
Any one KNOW the difference between the VHA and the regular?
#1030
More space on the outer end, but the geometry is identical. You can see that the 90° arm stiffener is located more towards the center of the arm.
Just my two cents on the current diff case, it keeps people from buying the car, so it should be addressed with the 22X or however the next 2WD will be called. Also, a layback/LD gearbox option IMHO is mandatory today. One of the reasons we race on astroturf in Europe is the fact that you can run in the rain or shortly afterwards, and if you ever slipped on wet astro, you can imagine that a full laydown car is not always the best option. For people running on low to medium grip dirt, it is a no-brainer anyway.
#1031
Well, despite my wishlist concerns (as also noted in the 22X “Next Gen” 2WD wishlist thread), this happened:
So, who’s gonna be the first one to welcome me to the family?
Anyway, My concerns about addressing the gearbox possibilities shared here so far (easy diff access, possibly the return of a layback option for weight distribution), lay in your hands, TLR... I made a leap of faith, and with Gil Jr. back in a more significant role (at least significant enough to formally announce it), I have faith that you guys will strive to make the 5.0 even better.
#1032
If there had been an AC version of the Elite before I went for the CAL3, I might have been able to welcome you, but as it is, I'll have to wait for the new wheeler to return to TLR. It's been almost two years since my last Losi, and the 22T 4.0 and I had a rough start and we split after I could not get new outdrives for the planetary gear diff for a while. As it seems, support issues in Germany have been resolved and I am looking forward to the 22X-4. Chances are high I'll write a built report/review for petitrc.
But back to topic; how do you guys like the front axle bearing inserts? I did not drive the truck long enough to love or hate them. Should they be included in the neXt generation 22 or not? Do you use them as an adjustment option at all or would you prefer a fixed setting instead?
#1033
#1034
#1035
