Like Tree833Likes
TLR 22 5.0
Old 09-25-2019, 04:06 AM
  #1006
OldSkool's Avatar
Originally Posted by Alexv2024
I don't know about shrinking but it does turn them into useless rocks. Or at least the hardest tires I've ever held for indoor off road racing, and thus slow and useless.
Maybe you can pop them in the oven for less change in the tire, but I think it'll still significantly change the tire. Anything other than carefully cutting the tire off the wheel will likely ruin the tire for racing use.
Originally Posted by waitwhat
Clay compound tires don't like acetone. It causes the tire to shrink. I've witnessed a buddy turn a set of stadium truck tires into basically a set of buggy rears. He soaked them in acetone though, just the fumes should not change the tire shape. Just don't leave them in the bucket for too long. If the rubber feels a little dry after acetone fumes, spray some wd40 on them to moisturize the rubber.
I used to drop the tyres straight into a bucket of water as soon as I removed them. We found the water stops the acetone in the tyre from evaporating and drawing out all of the natural oils in the rubber. Give it a go.
OldSkool is offline
Old 09-25-2019, 10:56 AM
  #1007
Trader Rating: 16 (100%+)
zipperfoot is offline
Old 09-25-2019, 04:29 PM
  #1008
Trader Rating: 115 (100%+)
Default 22 5.0 AC Carbon Shock Towers
Our track has switched over to carpet so it's all new to me. I'm thinking about picking up a +2 front shock tower. If i get the +2 for the front should i get the +2 for the rear? Do you run the 2mm on the shock eyelet with the +2 towers? Is the standard tower with the 2mm shock eyelet the same as the +2 tower with the standard shock eyelet? Does it really make that much difference with the +2 towers?
Appreciate any comments.
slider3 is offline
Old 09-25-2019, 04:39 PM
  #1009
RazorRC's Avatar
Originally Posted by slider3
Our track has switch over to carpet so it's all new to me. I'm thinking about picking up a +2 front shock tower. If i get the +2 for the front should i get the +2 for the rear? Do you run the 2mm on the shock eyelet with the +2 towers? Is the standard tower with the 2mm shock eyelet the same as the +2 tower with the standard shock eyelet? Does it really make that much difference with the +2 towers?
Not sure on your situation, but I'd seriously consider buying a 5.0 Elite and moving the AC parts over to that car. +2 towers alone are over $40, and you'll get a bunch more stuff that you'd probably like. Try to sell your old 5.0 for maybe $200-220 and you could have a really nice car for about $100 more than what you're paying just for towers.
zipperfoot and token like this.
RazorRC is offline
Old 09-26-2019, 01:10 PM
  #1010
Essejay's Avatar
He may have also to buy both roll bars and a pinion gear diff if he wants to run on carpet.
Essejay is offline
Old 09-26-2019, 02:00 PM
  #1011
RazorRC's Avatar
Yah, I'm assuming he currently has an AC and can move all the carpet parts over to the Elite. Then sell the old chassis as a "dirt car" without the carpet parts on it and put the ball diff, etc. from the Elite there.
RazorRC is offline
Old 09-26-2019, 06:41 PM
  #1012
Razor Rc. I do have an AC and itís a interesting idea you have. Not sure how well it would sell and what I could get for it once I mention I turned an AC into a DC buggy. The buggy is mint, only been on the track one day.
dcerven94 likes this.
slider3 is offline
Old 09-29-2019, 02:37 PM
  #1013
Trader Rating: 28 (100%+)
For anyone that understands the pill system, what insert would i use to achieve 1 or 2 degrees of rear toe instead of the stock 3 degrees? Would like to run 2 antisquat and either 1 or 2 degrees of toe. Still a little confused myself on the pill system.
dbracn is offline
Old 09-29-2019, 03:04 PM
  #1014
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Hi all,
Just looking at picking up a DC elite to race in 17.5t stock class on a high grip dirt track (SIC surface - its a dirt/gravel surface sprayed with a 'glue' to seal the surface, making it hard as a rock and course sand paper like surface).
Any ideas why parts to get (both tuning and spares)? I am new to Off-Road but not racing.
Do Xray XB2 wheels fit this car?
And what setup to start with?
Many thanks in advance.
DirtyDog3375 is offline
Old 09-29-2019, 03:11 PM
  #1015
TurnNBurn's Avatar
Ugh, buggies have gotten so complicated, lol. When I was looking to maybe just continue with AE, it was bewildering just trying to figure out what parts would be handy to have to convert the 6.1 from one surface to the other (I'm not willing to invest in two separate buggies just yet). I live in Florida, and while the two tracks that I have closest to me are both traditional dirt tracks, if I should decide that I want to travel for a few races, there are at least a few tracks upstate that are A/C surfaces. Then there's the fact that I might want to start off running 17.5 - is there any extreme advantage to preparing the car specifically with the SR setup? The Elite is attractive to me no matter what, because, holy cow, they are pretty much throwing the kitchen sink in that kit as far as optionals go, and the price is ridiculously good for what you get, even if I do have to pay the $16 for a set of wheels.
TurnNBurn is offline
Old 09-30-2019, 06:54 AM
  #1016
purplerain's Avatar
At my indoor clay track, all of us run the standard slipper setup as it makes the acceleration and jumping more predictable. MIP pucks are the way to go if you want to be really fast in stock anyways. Nothing wrong with buying the non-SR versions.
TurnNBurn likes this.
purplerain is offline
Old 09-30-2019, 10:59 AM
  #1017
TurnNBurn's Avatar
Thanks for the feedback. Do you also run the optional weight under the gearbox/C block?
Old 09-30-2019, 11:32 AM
  #1018
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
+2 tower with +2 eyelets doesn't change anything. +2 eyelets give 2mm more down travel and 2mm less up travel. +2 towers give 2mm more up travel and 2mm less up travel.
Originally Posted by DirtyDog3375
Hi all,
For spares, a set of arms, a pack of ball cups, and an extra set of hubs and spindles should be good to start.
No, X-Ray wheels won't fit in the front and the rears might be able to fit, but I'm not sure/familiar with their off-set.
Try this setup - http://www.tlracing.com/ProdInfo/Fil..._OCRC-8-19.pdf
Frank Root is offline
Old 09-30-2019, 02:39 PM
  #1019
Thanks heaps Frank! Much appreciated.
One last question, gear diff vs ball diff? I see in the setup and all the dirt based setups only use ball diffs (even on high grip tracks), why is that? how often do you rebuild them?
Thanks again,
Leonard.
Old 09-30-2019, 09:53 PM
  #1020
Trader Rating: 43 (100%+)
Any guys building a Kinwald tribute buggy. I have a couple of BK Bar rear tires for sale PM me for price. Never opened .
zipperfoot likes this.
Phillip F is offline
