Like Tree892Likes
TLR 22 5.0
Old 09-08-2019, 09:00 PM
  #946
Michael#81's Avatar
Trader Rating: 271 (100%+)
It is basically the same rear pill system that the b6.1 uses other then the losi starts at center dot and center dot being 3* toe and 2* squat. It is easy just to leave the C block at the center dot and adjust everything from the D block because it is easier to get to. The stock dots with everything in the center is 3* of Toe and 2* of anti squat.
For an easy example If you use the .5 out center dot in the D block you are essentially only changing the toe to 3.5* and the anti-squat will stay 2*, same goes for the 1* center dot out you changed 1* from the 3* base and went to 4* of rear toe but did not change the anti-squat. Now if you moved both the C and D pills to the center 1* pill all the way in you are still at 3* toe and 2* squat you just narrowed the track width and same way for moving the center pills all the way out you would widen the track width but keep the same 3* toe and 2* squat. If you moved the pills the same in both the C&D blocks you are still you still have the stock Toe 3* and Anti-squat 2* but you are changing roll centers and track width at that point.
This pill systems not only allows you to change rear toe and anti-squat it also allows you to play with roll center and track width. It is a lot more tuning options but can be difficult to understand.
Michael#81 is offline
Old 09-08-2019, 11:19 PM
  #947
Trader Rating: 16 (100%+)
Slashripper likes this.
zipperfoot is offline
Old 09-09-2019, 12:44 AM
  #948
RazorRC's Avatar
If you have to ask...
RazorRC is offline
Old 09-09-2019, 04:49 AM
  #949
purplerain's Avatar
Originally Posted by zipperfoot
Difficult to understand for sure, but is this info really needed? I hate to call anyone out but, I see so many people with the latest chargers, tire warmers, sauce, the latest gear, etc. but can't drive at all. What's the point really?
Unless you are a Pro are you even going to notice the difference?
Learning setup (especially the complicated concepts) takes time and people might as well start out of the gate learning setup theory, regardless of skill level. I donít buy into the belief that good setup doesnít matter at lower skill levels, because Iíve worked on the cars of people running novice and they instantly began learning at a quicker rate.
Pistol123, trf211 and xenon55 like this.
purplerain is offline
Old 09-09-2019, 06:07 AM
  #950
Trader Rating: 119 (100%+)
Default 22 5.0 AC Thoughts
Our track is switching over to carpet (EOS). Been running the 22’s for a number of years. I have never ran on carpet and looking at the 22 5.0 AC. I like some things about the B6.1 so I’m considering it also. Would appreciate any feedback or opinions on the 22 5.0AC before I make my decision. Out of the box set-up, upgrades needed, is the VHA conversion necessary? Thanks in advance.
slider3 is offline
Old 09-09-2019, 07:20 AM
  #951
Originally Posted by slider3
Our track is switching over to carpet (EOS). Been running the 22ís for a number of years. I have never ran on carpet and looking at the 22 5.0 AC. I like some things about the B6.1 so Iím considering it also. Would appreciate any feedback or opinions on the 22 5.0AC before I make my decision. Out of the box set-up, upgrades needed, is the VHA conversion necessary? Thanks in advance.
Iím considering the 5.0 too for black carpet. Do you get the elite or the ac?
shark2288 is offline
Old 09-09-2019, 07:38 AM
  #952
Trader Rating: 137 (98%+)
I would get the elite and then add the gear diff and sway bars
ashxxx is offline
Old 09-09-2019, 02:20 PM
  #953
Old 09-09-2019, 07:20 PM
  #954
fifi's Avatar
I've seen a chart for the pills and asso.
Would be nice to have the same one for our 22.
Easier for everyone to understand 🤔
fifi is offline
Old 09-09-2019, 08:48 PM
  #955
Michael#81's Avatar
Absolutely it is needed. Toe and anti squat are 2 main adjustments on the rear end of the car. The roll center and track width changes most will not feel but I guarantee if you go from the stock 3* rear toe and change it to 2* toe or 4* toe you will notice a huge difference in how the car drives. I agree a lot of people buy the latest and greatest stuff and cant drive to save their lives. They should be spending that money practicing and just making changes to the car to see what they actually do. I am not a pro by no means but I can tell when I make a change to my car what it did and know the changes to make to achieve what I am looking for.
J@UNE, zipperfoot and JAE like this.
Old 09-10-2019, 12:01 PM
  #956
Trader Rating: 43 (100%+)
My TLR 22-5.0 Elite is ready for the track. Will race it on a dirt track first see a if it's better than my dialed B6.1
Phillip F is offline
Old 09-10-2019, 01:45 PM
  #957
RazorRC's Avatar
Are the pills really that hard?
Go steeper (higher front or lower rear) to increase anti-squat.
Go more pointed in (narrower front or wider rear) to increase rear toe.
Both wider to go wider track width.
Both up to raise roll center.
RazorRC is offline
Old 09-10-2019, 11:23 PM
  #958
who races here on real dirt...outdoor?
Old 09-11-2019, 10:45 AM
  #959
Trader Rating: 23 (100%+)
outdoor dirt here but our track is always grooved and well prepped
Jfowler is offline
Old 09-12-2019, 08:17 AM
  #960
Rubbaneck's Avatar
Outdoor, real dirt, real roost, real fun!
Rubbaneck is offline
