Like Tree833Likes
TLR 22 5.0
Old 08-05-2019, 09:55 AM
  #841
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by dbracn
Frank,
One question regarding putting the sr driveline on the new elite. When running the axles I know you can use either aluminum or steel bones but what about the rear axle. Should you run the regular sr axle or the new rear axle. Concerned about running the new hubs and having the correct parts to fit.
Thanks,
You need to use the new rear axles, the SR axles will not fit. The rest is good to go.
Originally Posted by Kswarrior
So is this the major difference between the 5.0 and the 5.0elite minus the carbon fiber, titanium, and other goodies? Looks like the caster block is a bit different to accommodate front sway bar. Was talking to a fellow racer today and he was telling me the steering geometry on the elite is different than the 5.0 (havent read anything to make me believe that). Appears to me the major difference is all in the rear with these parts.
Key Handling/Adjustment Improvements
1. VHA rear hub setup. TLR334069
2. Adjustable Inner rear pivots TLR334062
3. G3 3.5mm Shock Shaft setup. TLR333004
All 3 can be converted using the part numbers as above.
Then, it comes with all the goodies, carbon parts, aluminum parts, etc.
Frank Root is offline
Old 08-05-2019, 02:03 PM
  #842
Trader Rating: 35 (100%+)
Originally Posted by ussprinceton
which track in NC do you go to?
Ho-B-RC Park in Northgate mall in Durham, NC.
We just recently converted it from onroad carpet to carpet offroad. There's been some great racing there the last few weeks. I just need to get some more trigger time to be competitive.
Best part - it's air conditioned!!!
Noche likes this.
xjwolfpacker is offline
Old 08-05-2019, 08:45 PM
  #843
Thank you for clearing that up for me Frank pretty much the way I was thinking.. I like my 5.0sr just the way it is, only had like 12 race days on my 4.0sr and everyone said the 5.0 wouldn't make me faster, I disagree. Car is a lot easier for me to drive. I liked the 4.0, was a great buggy to get back in RC, but I was instantly faster with the 5.0. So glad I went ahead and bought it. For what's in the box the elite is a smoking deal.. I'm still fiddling with the basic adjustments and will leave you pros to the advanced stuff.. lol
Kswarrior is offline
Old 08-07-2019, 01:40 PM
  #844
Trader Rating: 16 (100%+)
zipperfoot is offline
Old 08-07-2019, 02:08 PM
  #845
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Originally Posted by zipperfoot
Anyone else having issues with their Gen III shocks leaking? Mine weep a bit, but my son's are actually leaking big time. We built them the exact same way. We each have about three practice sessions on our 5.0 SR's.
He called Losi and the person he spoke with was let's say less then cheerful? He is going to send us a rebuild kit.
I read there is a rebuild or upgrade kit, and that the Elite kit comes with the 3.5 shafts sort like a retro fit. Wonder if anyone else has experienced the same or found a solution.
Looks like you race at Hobby Action. Talk to Tanner or Randy about the shocks.
zipperfoot likes this.
Wildcat1971 is offline
Old 08-09-2019, 08:28 PM
  #846
Trader Rating: 38 (100%+)
I picked up a 22 5.0 AC a few weeks ago. I havenít run it yet, still building it, but so far Iím impressed with the initial quality. A few questions though, because Iíve been out the hobby for over a decade and never raced before. Because I plan on racing the stock class, my local shop recommended a direct drive (# TLR332043). But I donít see one listed as an option in the back of the manual, unless I missed it. If it will work, what spur and pinion would you recommend as a starting point? I believe the direct drive came with a 69 and 75 spur. Iím going to use a Tekin 17.5 G3 Spec-R and Tekin recommends 4-5 teeth less on the pinion than normal on this motor.
xenon55 is offline
Old 08-09-2019, 09:00 PM
  #847
Trader Rating: 28 (100%+)
xenon55,
I run the direct drive on carpet with several motors. For the r1 motor I run 69/29 while with a motiv or team powers I run 72/27 if that gives you a good starting point. Ive heard that the tekin gears lower but it should be based on the size of the track as well. Hope this helps.
xenon55 likes this.
dbracn is offline
Old 08-09-2019, 09:06 PM
  #848
The people running the carpet offroad program are doing a good job.
Noche is offline
Old 08-09-2019, 09:22 PM
  #849
Applesauce's Avatar
Trader Rating: 15 (100%+)
Hey Frank Root
What would I need to do to turn an elite dc in to an ac?
Applesauce is offline
Old 08-09-2019, 11:08 PM
  #850
xenon55 likes this.
Old 08-09-2019, 11:36 PM
  #851
Will the 3 and 4 gear standup transmissions fit on the elite car?
magnushedqvist is offline
Old 08-09-2019, 11:42 PM
  #852
TLRacing
Frank Root's Avatar
Originally Posted by Applesauce
Hey Frank Root
This should cover it...
Gear Diff - TLR232088 or TLR232101
Springs - TLR233052 and TLR233057
Pistons - TLR333016, TLR333018
Sway Bars - TLR334040, TLR334055
TLR234110 (just a change to stiff rear arms)
Change to 3mm shock shafts - TLR233027 x 2, TLR233028 x 2, TLR233034, TLR233033, TLR233025 x 2. TLR233026 x 2
Tuning Parts, also not in AC kit:
Brass - TLR331039, TLR334020
Old 08-10-2019, 08:46 AM
  #853
xenon55,
Really depends on the motor. For 17.5 I run 69/29 and my buddy runs 69/27. Our motors are different but our speeds are the same. His is single stack, mine is not.
Ok. Based on what you guys are running, Iíll start with 69/25, check temps and see how it goes. Thanks guys.
xenon55 is offline
Old 08-11-2019, 06:37 PM
  #854
Default Set up sheet for black carpet
Which set up sheet should we use for new, smooth black carpet? The track is medium/large usually with two small radius 180ís and the rest sweepers of various sizes.
4wdfull is offline
Old 08-12-2019, 08:46 AM
  #855
TLRacing
Frank Root's Avatar
http://www.tlracing.com/ProdInfo/Fil...ochet-7-19.pdf
