Like Tree809Likes
TLR 22 5.0
Old 08-01-2019, 03:45 PM
  #826
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by JAE
VRP Pistons: Used these on a Kyosho awhile back with good results. Anyone use these on the 5.0? Effects?
I know Tyler Jones runs them a bit. You might reach out to him. I don't believe he comes on here though.
JAE likes this.
Frank Root is offline
Old 08-01-2019, 08:40 PM
  #827
Trader Rating: 28 (100%+)
Frank,
Whats included in the vha conversion? Saw it on the website just didn't list what comes in it.
dbracn is offline
Old 08-02-2019, 10:26 AM
  #828
TLRacing
Frank Root's Avatar
Originally Posted by dbracn
Frank,
Comes with:
Suspension Arm, Rear, LH, 22 5.0, VHA 1
Suspension Arm, Rear, RH, 22 5.0 VHA 1
Hub, Rear, 22 5.0 2
Insert, Hinge Pin, Rear Hub, 0-4mm, 22 5.0 2
Insert, Hinge Pin, Rear Hub, 1-3mm, 22 5.0 2
Insert, Hinge Pin, Rear Hub, 2mm, 22 5.0 2
Axle, Rear, CVA, 22 5.0 2
Mount, Ball Stud, Rear Hub, Black, 22 5.0 2
Pin, Coupling, CVA, 22 5.0 2
Ball Stud, 4.8mm x 8mm, 22 2
Spacer, Ball Stud, 2mm, Black Alum, 22 2
Spacer, Ball Stud, 1mm, Black Alum, 22-4 4
Ball Bearing, 5mm x 13mm x 4mm, Rubber Seal 2
Ball Bearing, 10mm x 15mm x 4mm, Rubber Seal 2
Screw, M3 x 0.5mm x 10mm, Button Head, Stl, BO 4
lbckevin likes this.
Old 08-03-2019, 02:21 PM
  #829
Trader Rating: 16 (100%+)
zipperfoot is offline
Old 08-03-2019, 03:15 PM
  #830
thirtydaZe's Avatar
Trader Rating: 35 (100%+)
Originally Posted by zipperfoot
Somebody was telling me the diameter of the Gen III shock shafts is thinner than the Gen II shafts. I though it was the other way around.
Can someone clarify for me the difference?
Yes
G3 3.0mm
G2 3.5mm
thirtydaZe is offline
Old 08-03-2019, 04:03 PM
  #831
Trader Rating: 92 (100%+)
The new G3 shocks come with 3.5mm shafts as in the coverion kit TLR333004. Front shafts TLR333009, rear shafts TLR333010 as I am not sure
if you can right now but soon I hope.
sksdean is offline
Old 08-03-2019, 04:08 PM
  #832
Alexv2024's Avatar
....So its back to G1 then
Alexv2024 is offline
Old 08-03-2019, 06:29 PM
  #833
Bobby Z's Avatar
no not at all. G3 shocks with 3.5mm. shock shafts and shock bodies to accommodate the shafts. You still retain the G3 parts like screw on piston, locked spring perch in three different heights, thinner shock collar for lower ride height possibilities. Best of both worlds!!
Bobby Z is offline
Old 08-03-2019, 09:50 PM
  #834
Old 08-03-2019, 10:05 PM
  #835
Zipperfoot,,
5.O comes with 3.0 shafts. They are smaller than the previous 4.0. Most guys on clay liked the 4.0 shocks better than the 5.0 as it seems to handle better. Tlr came up with a conversion for the 5.0 shocks to make them the size of the previous 4.0 shocks. You could just run 4.0 shocks if you had some laying around to see which you like better. The advantage to the conversion kit is that you keep most of the parts of your current 5.0 shocks and just change the shaft and bodies. As someone above mentioned you keep the screw on pistons, lower collars, and locking bottom spring cups. Hope this helps. It was mentioned in the video that a lot of drivers prefer the current 5.0 shocks(3mm) for carpet but prefer the 5.0(3.5) conversion for high bite clay.
zipperfoot likes this.
dbracn is offline
Old 08-03-2019, 10:07 PM
  #836
Frank,
One question regarding putting the sr driveline on the new elite. When running the axles I know you can use either aluminum or steel bones but what about the rear axle. Should you run the regular sr axle or the new rear axle. Concerned about running the new hubs and having the correct parts to fit.
Thanks,
dbracn is offline
Old 08-03-2019, 11:29 PM
  #837
RazorRC's Avatar
Should call them G3.5 shocks IMO. Different shock bodies, shafts, seals and presumably seal spacer as well.
RazorRC is offline
Old 08-04-2019, 12:19 AM
  #838
Originally Posted by Frank Root
Comes with:
Hub, Rear, 22 5.0 2
So is this the major difference between the 5.0 and the 5.0elite minus the carbon fiber, titanium, and other goodies? Looks like the caster block is a bit different to accommodate front sway bar. Was talking to a fellow racer today and he was telling me the steering geometry on the elite is different than the 5.0 (havent read anything to make me believe that). Appears to me the major difference is all in the rear with these parts.
Kswarrior is offline
Old 08-04-2019, 07:05 PM
  #839
ussprinceton's Avatar
Originally Posted by xjwolfpacker
I just raced it for the first time tonight. Loved it.
which track in NC do you go to?
ussprinceton is offline
Old 08-05-2019, 12:16 AM
  #840
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
The steering is not different. I think the front arms are the stiff material and the mud guards. aside from the c and d mounts, most are just the upgrades people use. just a decked out car,
Wildcat1971 is offline
