Like Tree892Likes
TLR 22 5.0
Old 07-14-2019, 07:20 PM
  #796
purplerain's Avatar
Could someone running Xpert servos give the proper servo shim measurement? Not listed in the manual...
purplerain is offline
Old 07-14-2019, 10:14 PM
  #797
Default HELP
Hey I drive on somewhat loamy dirt. We spray so it gets a little tacky at times. But my 5.0 sr wants to push real bad in the corners. I know it could be my driving but it seems like my setup is a tad off. Any info is appreciated!
Zachxriah is offline
Old 07-15-2019, 02:19 AM
  #798
Pistol123's Avatar
Try lowering your front roll centre (1mm washer under inner ball stud) or raising your rear roll centre.
Pistol123 is offline
Old 07-15-2019, 02:25 PM
  #799
slakr's Avatar
Trader Rating: 36 (100%+)
I'm using the 2mm shims.
slakr is offline
Old 07-15-2019, 02:41 PM
  #800
Trader Rating: 137 (98%+)
Ac on carpet is anyone playing with the front vla. When and where should u use this option.
ashxxx is offline
Old 07-16-2019, 04:53 PM
  #801
Trader Rating: 166 (100%+)
Looking for a setup for a smallish indoor office depot carpet carpet track. My car pushes entering into the corner and through sweeper turns it wants to "float" towards the outer pipe ( like I don't have enough side grip). I tried Frank Roots setup, and it did not work at all on my home track.
jpcopeland1 is offline
Old 07-16-2019, 05:06 PM
  #802
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
What tires, what carpet? What didn't work about the setup? Also, which setup? I have two posted.
Frank Root is offline
Old 07-17-2019, 07:34 AM
  #803
happens with jconcepts, proline, Schumacher. Carpet is Office Depot grey has about 11 months on it so it’s well worn in and super high bite. Setup I tried is from the ricochet rc race. I have the exact same setup on it now. Nobody else here runs TLR so I’m on my own as far trying to get it dialed in. Ended up running my XB2C, but want to get the TLR competitive.
Old 07-17-2019, 08:57 AM
  #804
TLRacing
Frank Root's Avatar
happens with jconcepts, proline, Schumacher. Carpet is Office Depot grey has about 11 months on it so itís well worn in and super high bite. Setup I tried is from the ricochet rc race. I have the exact same setup on it now. Nobody else here runs TLR so Iím on my own as far trying to get it dialed in. Ended up running my XB2C, but want to get the TLR competitive.
Ok, so what is your go to tire? Not just the brand, but the compound and tread patterns for front and rear?
I've found tires to have a lot to do with the feel of a car on carpet.
And what are you looking for the car to do better? The more specific info I get, the more specific info I can give back.
Old 07-17-2019, 09:16 AM
  #805
[QUOTE=Frank Root;15481266]Ok, so what is your go to tire? Not just the brand, but the compound and tread patterns for front and rear?
And what are you looking for the car to do better? The more specific info I get, the more specific info I can give back.[/QUOTE
it needs to not push, better off power and on power steering, better side bite. My go to tire right now are the jconcepts swagger fronts, and Nessieís rears when I can get them. My back up tire is a Schumacher cut stagger front, and cactus rear (yellow compound). There was a track change over the weekend that has more of a flow to it and is higher speed so I intend on trying a thinner front sway bar and thicker rear. Go back to stock pistons with 450/350 cst xray shock oil, and drop the diff oil to 5k from 7k to try and keep the rear from overdriving the front end causing the push Iím having. I will also try 1mm on the inner front ballstud on the camber block, change roll centres, and add more drag break on the muchmore speed control Iím running in it (was suggested by a yokomo driver). This is a mod car with a 6.5 running 78/21 for gearing.
Old 07-17-2019, 09:30 AM
  #806
TLRacing
Frank Root's Avatar
It needs to not push, better off power and on power steering, better side bite. My go to tire right now are the jconcepts swagger fronts, and Nessieís rears when I can get them. My back up tire is a Schumacher cut stagger front, and cactus rear (yellow compound). There was a track change over the weekend that has more of a flow to it and is higher speed so I intend on trying a thinner front sway bar and thicker rear. Go back to stock pistons with 450/350 cst xray shock oil, and drop the diff oil to 5k from 7k to try and keep the rear from overdriving the front end causing the push Iím having.
Here are a few things to try.
1. Increase front camber to 2 deg, even try upto 2.5 deg.
2. Got to #1 front camber link inside.
3. Increase the front wing angle. There are two dimples, just drill 2 or 2.1mm holes there and install M2.5 BH screws (like the shock bleed screws) to lift the rear of the front wing.
4. Change front shock position to 2-Middle
5. Move the hubs back 1mm.
6. Remove any weight under the battery and install a 2nd weight plate under the electronics.
Old 07-17-2019, 10:20 AM
  #807
ok. Should I mess with trail any? Or leave it at 4mm. And what exactly does that setting do?
Old 07-17-2019, 10:48 AM
  #808
TLRacing
Frank Root's Avatar
More trail will smooth out off-center steering, but give more mid-corner, and vice-versa. I've tried less, and preferred 4mm myself.
Old 07-17-2019, 11:55 AM
  #809
[QUOTE=Frank Root;15481347]More trail will smooth out off-center steering, but give more mid-corner, and vice-versa. I've tried less, and preferred 4mm myself.[/QUOTE
ok. Something else to play with. Noob question, how do I shim up the rear wing 4mm. Just stack the carbon parts?
Old 07-17-2019, 12:43 PM
  #810
ussprinceton's Avatar
there are no Race Tracks around within a 60 mile radius in my area
ussprinceton is offline
