Like Tree886Likes
TLR 22 5.0
Old 06-10-2019, 05:09 AM
  #781
Originally Posted by enare
The waterfall on my buggy broke. Do I need to replace it or is it ok to leave it off?
Replace it. I wouldn't run the 5.0 without it. You risk bending the chassis.
jmitchell is offline
Old 06-10-2019, 09:37 AM
  #782
Thank you for the feedback. I bought one on Ebay.
enare is offline
Old 06-12-2019, 09:30 PM
  #783
Im trying to understand diff height adjustments when to up and when to go don on adjustment?
zeestraten46 is offline
Old 06-12-2019, 10:45 PM
  #784
Pistol123's Avatar
You are trying to keep the driveshafts level by raising the diff for lower ride heights.
Pistol123 is offline
Old 06-14-2019, 10:56 PM
  #785
Trader Rating: 15 (100%+)
You are also altering CG slightly when changing diff height .
Slashripper likes this.
trigger is offline
Old 06-15-2019, 09:44 AM
  #786
The dogbones are their most efficient and free when they are flat and straight out from the diff. Anytime the dogbones are at an angle from the diff and you are on throttle the drive line will want to straighten back up again. For example if you are heavy on throttle and the diff is sitting lower, the drivetrain will be trying to straighten out and force the rear end of the buggy upward. These opposing forces of the rear end squatting with throttle and the dogbones trying to straighten back out will effectively drive the tires harder into the surface and create a stronger on throttle bite.
As drivers change the suspension for different track surfaces via the axle heights, there has to be a matching adjustment at the diff or else the dogbone plunge gets all out of whack and you start hitting the dogbones on the outdrives and stuff. So as they mentioned above it's mainly to keep the geometry the same when switching suspension around.
If you were to keep your suspension the same and just adjust the diff height. Lower = more on throttle bite, more responsive off throttle. Higher = buggy is a little freer on throttle and more stable off throttle.
Pistol123 and RCDaddy2105 like this.
trf211 is offline
Old 06-29-2019, 01:13 PM
  #787
psycho02's Avatar
Trader Rating: 14 (100%+)
Anyone have any experience running a 13.5 in this car? Starting point for gearing?
psycho02 is offline
Old 07-03-2019, 12:39 AM
  #788
Trader Rating: 166 (100%+)
Manual suggests 72/24.
jpcopeland1 is offline
Old 07-03-2019, 04:43 AM
  #789
JPAPA26's Avatar
Trader Rating: 25 (100%+)
what is the difference between 3.0 4.0 or 5.0 wheels/rims?
I see they are different part #'s but look the same and the 4.0 front wheels look the they have 2 grooves where tires mounts and 5.0 only has 1 grove thanks in advance
JPAPA26 is offline
Old 07-03-2019, 05:10 AM
  #790
Pistol123's Avatar
Sounds like you are looking at the slim wheel for the 5.0 which is just a machined down wheel used on the 4.0 and 5.0. These are mainly used for Schumacher staggered ribs which very slim and used mainly on astro, carpet and grass tracks.
jpcopeland1 likes this.
Old 07-11-2019, 02:00 AM
  #791
Taman's Avatar
Trader Rating: 67 (100%+)
Hi, is this bag part of the TLR 22.50 kit? Thanks
Taman is offline
Old 07-11-2019, 04:58 AM
  #792
Yes it's just spare parts.
Old 07-11-2019, 07:30 PM
  #793
R/C Tech Elite Member
I_NeedBigDrink's Avatar
With the 4th of July sale i picked up Rawspeed premounts, new body, and paint. Paint is testors color shift emerald-blue. Been looking for this kind of color shifting paint since Tamiya's blue-green was discontinued. It seems to work, if it starts to flake after some crashes I'll share it.
EDIT: Unfortunately the gamble didnít pay off, this paint doesnít adhere to lexan. Back to the Tamiya Pink/Gold!
the clear lexan bits I made myself, inspired by another user on here.
I_NeedBigDrink is offline
Old 07-14-2019, 11:45 AM
  #794
ljl23's Avatar
Hey guys, I am considering upgrading to a 5.0 over my B6. I was wondering, has the car proved to be durable overall? What sort of extras might I need just in case?
ljl23 is offline
Old 07-14-2019, 01:18 PM
  #795
I once crashed into a metal pillar at pretty decent speed, but hit it right on the front hingepin/bumper. It snapped the head of the hingepin off and slightly tweaked the aluminum brace, so I just replaced them, pretty cheap. However someone crashed on the same pillar and broke the front arm. Id say carry spare front arms since front collisions are more likely, but that was my only broken part (apart from wings) and Iíve been running since January.
