Like Tree886Likes
TLR 22 5.0
Old 05-31-2019, 11:56 AM
  #766
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by fifi
Anyone have a standard setup for stand-up transmission on 5.0?
Haven't seen any team guy's running it but I am sure they have tested it
We haven't run stand up since the early days of the 4.0, at least the main team drivers. I'm sure someone has though.
Frank Root is offline
Old 05-31-2019, 03:59 PM
  #767
Bobby Z's Avatar
Here is my setup for standup in my 5.0. Only have two races so far so may need more tweaks
Bobby Z is offline
Old 05-31-2019, 04:02 PM
  #768
Bobby Z's Avatar
Originally Posted by Aaronv
Stand up install complete. I really think this should be included in the kit yet. Not all of us have the opportunity to run indoors. I will say this is the last Orion motor I buy it requires dermel work to mount. The build was as usual Tlr perfect. Always a pleasure to build these kits. Also thank you Bobby Z for the setup help.
who makes the battery mount?
Bobby Z is offline
Old 05-31-2019, 07:53 PM
  #769
psycho02's Avatar
Trader Rating: 14 (100%+)
Any chance TLR will produce pistons with the 1mm hole already in them?
psycho02 is offline
Old 05-31-2019, 08:53 PM
  #770
Default Replacement dog bone pin 2.35mm or .0925
For all other brands I'm able to source dog bone pins except for tlr. No matter where I search I'm unable to find 2.35mm or .0925 pins. Can anyone point me in the right direction?
jlett21 is offline
Old 06-01-2019, 01:54 PM
  #771
fifi's Avatar
Thx for the stand-up setup.
I will give a try.
fifi is offline
Old 06-03-2019, 07:42 AM
  #772
TLRacing
Frank Root's Avatar
We don't have plans too. Because the pistons are machined, we have minimum order quantities, which make it hard to cover the quantities for the viable piston options, and adding 1x 1.0mm hole is pretty straight forward for those wishing to try it.
For what it is worth, I run 1.6 front, 1.6/1.7 rear pistons without any extra holes, which we offer both.
Old 06-03-2019, 07:45 AM
  #773
psycho02's Avatar
Youíre running a 1.6/1.7 split in the rear?
psycho02 is offline
Old 06-03-2019, 11:20 AM
  #774
RazorRC's Avatar
I think itís one hole 1.6 and one hole 1.7 on the same piston, not different pistons in each shock.
RazorRC is offline
Old 06-03-2019, 11:40 AM
  #775
TLRacing
Frank Root's Avatar
Yes.
Old 06-05-2019, 12:01 PM
  #776
since he never bothered responding, I liked it myself and was searching around, it looks like this one below
https://rclyfe.com/store/Battery-Hol...6-1-p114698416
scott_0 is offline
Old 06-06-2019, 09:09 PM
  #777
Trader Rating: 19 (100%+)
Can someone tell me what does these 4 settings do and does the -3 give you more steering ?
speed101 is offline
Old 06-06-2019, 09:26 PM
  #778
TLRacing
Frank Root's Avatar
The lower you go, the less twitchy and softer the front end will be. Higher can be a little twitchier and is generally stiffer feeling. On clay and carpet, we run LRC (2mm) 99% of the time lately.
Old 06-07-2019, 04:51 AM
  #779
psycho02's Avatar
right. I got that.
psycho02 is offline
Old 06-08-2019, 04:56 PM
  #780
The waterfall on my buggy broke. Do I need to replace it or is it ok to leave it off?
enare is offline
