Like Tree886Likes
TLR 22 5.0
Old 05-28-2019, 06:43 PM
  #751
RazorRC's Avatar
Originally Posted by Pistol123
I was thinking that, on the 4.0 the screws are different between lay down and stand up.
The 5.0 chassis is 0.5mm thinner, so I guess you're supposed to use a 0.5-1mm shorter screw? I dunno, I haven't ran the standup on anything.
RazorRC is offline
Old 05-29-2019, 02:17 PM
  #752
Adddam's Avatar
Nice buggy. And while tlr are good quality, I find the plastics too tough. I mean in that screwing into them is a real downer for your hands.
Adddam is offline
Old 05-29-2019, 07:51 PM
  #753
Aaronv's Avatar
Trader Rating: 111 (100%+)
Stand up install complete. I really think this should be included in the kit yet. Not all of us have the opportunity to run indoors. I will say this is the last Orion motor I buy it requires dermel work to mount. The build was as usual Tlr perfect. Always a pleasure to build these kits. Also thank you Bobby Z for the setup help.
I_NeedBigDrink likes this.
Aaronv is offline
Old 05-30-2019, 07:30 AM
  #754
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
For reference, we sell less than 1 stand up conversion for every 50 kits we sell, so 1/50 racers buying a kit today is looking to run stand up roughly. Raising the cost by $30 to include layout parts, for 1/50 to benefit, and 49/50 to have more cost added for no benefit would probably not be the best decision.
I understand your view, it's just the way things have gone worldwide.
Frank Root is offline
Old 05-30-2019, 10:13 AM
  #755
damn that's a good looking build!!!!! wow! on the topic of the stand up, what's the benefit of the 4 gear stand up you have? compared to the 3 gear stand up I just bought for my 5.0?
scott_0 is offline
Old 05-30-2019, 10:21 AM
  #756
Trader Rating: 19 (100%+)
So what does the +2 rear shock tower help with on carpet
speed101 is offline
Old 05-30-2019, 11:34 AM
  #757
Pistol123's Avatar
From my Dex210 days, the 4 gear has the motor rotating the same direction as the wheels - when you accelerate more weight is transferred to the rear so good for very slippy/loose surfaces. I found it also gives you a car that is very throttle sensitive.
scott_0 likes this.
Pistol123 is offline
Old 05-30-2019, 01:58 PM
  #758
TLRacing
Frank Root's Avatar
It helps the car roll more to keep from flipping as easily.
MrLean likes this.
Old 05-30-2019, 04:28 PM
  #759
Lone Drifter's Avatar
I run a 3 gear standup Trans .....Its called a 22 3.0
J@UNE likes this.
Lone Drifter is offline
Old 05-30-2019, 08:46 PM
  #760
Any chance they will be releasing a 22t 5.0?
enare is offline
Old 05-30-2019, 09:15 PM
  #761
psycho02's Avatar
Trader Rating: 14 (100%+)
so plus 2 is just better everywhere?
psycho02 is offline
Old 05-31-2019, 08:10 AM
  #762
TLRacing
Frank Root's Avatar
In the rear, yes, I think so. In the front, I run standard on carpet currently, and +2mm front on dirt/clay.
Old 05-31-2019, 09:06 AM
  #763
fifi's Avatar
Anyone have a standard setup for stand-up transmission on 5.0?
Haven't seen any team guy's running it but I am sure they have tested it
fifi is offline
Old 05-31-2019, 09:46 AM
  #764
my bad lol, you meant an actual setup
scott_0 is offline
Old 05-31-2019, 10:20 AM
  #765
Maybe look into fitting slash arms onto the 5.0 then...
071crazy is offline
