Like Tree892Likes
TLR 22 5.0
Old 04-17-2019, 05:40 PM
  #646
Originally Posted by Losi Chaser
TLR334060
Thanks Bro, appreciate that!
Phugazi is offline
Old 04-17-2019, 06:03 PM
  #647
RazorRC's Avatar
Originally Posted by Phugazi
Ugh...so I just got the carbon front(TLR334061) and rear(TLR334059) +2mm towers in from Horizon for my 5.0AC buildup. I also just realized that the rear doesn't fit the stock tower piece. Researching online, I see there is a conversion kit (TLR334056) for the rear that includes the carbon piece and the tower base it mounts to. My question is, since I already have the rear shock tower, is there a part number for just the tower base? Or do I have to bit the bullet and buy the conversion kit to get the base?
I'm guessing the conversion kit doesn't have the +2 tower, so your way is probably better (buying +2 tower and base separately).
Also make sure your rear wing is raised a little when using the +2 tower, else the rear tires might hit the wing.
RazorRC is offline
Old 04-17-2019, 07:26 PM
  #648
slakr's Avatar
Trader Rating: 36 (100%+)
Looks like the tower is included... https://www.towerhobbies.com/cgi-bin...p?I=LXKRTY&P=7
slakr is offline
Old 04-17-2019, 08:11 PM
  #649
I also just fell into getting the +2mm carbon towers without the correct rear tower base. Also - I read that using the +2mm towers....you're supposed to lengthen the shocks, can you do that by using the optional shock ends or something else? I see the setup sheets show that Frank Root extends his front and rear stroke by 2.5mm.
CMadsen_24 is offline
Old 04-18-2019, 06:09 AM
  #650
jonbrown's Avatar
Would it be a worthwhile upgrade to run the 22 5.0 front hubs and spindles on the 22 4.0, using the 22 4.0 bell cranks?
Also does anyone know if the +2mm carbon front shock tower fits on the 22 4.0?
Many thanks,
jonbrown is offline
Old 04-18-2019, 06:34 AM
  #651
Yeah, I'm building my AC car now based off Frank's setup sheet so when I built the shocks, I extended the strokes to match using the upgraded towers. To follow up on what the OP noted, in one of the comments sections on his setup sheet, he mentions raising up the wing to compensate as well.
Phugazi is offline
Old 04-18-2019, 07:07 AM
  #652
I tried Frank's Carpet setup but was a little underwhelmed. It was a stable setup, very predictable but has a significant amount of understeer compared to my previous setup I need to invest in a fresh set of tires and I will test it again when I do to see if it is just the tires.
Djr8505 is offline
Old 04-18-2019, 08:50 AM
  #653
Was your previous the stock Astro/Carpet setup or something else?
Phugazi is offline
Old 04-18-2019, 01:51 PM
  #654
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
What tires are you running, and what type of carpet? Also, did you follow it 100%, or just closely? If so, what are the differences?
Frank Root is offline
Old 04-18-2019, 06:31 PM
  #655
lbckevin's Avatar
Trader Rating: 107 (99%+)
Frank....can you post your setup along with Barry Baker's +2 setup for OCRC ?
lbckevin is offline
Old 04-19-2019, 06:13 PM
  #656
Here is a copy of my most recent setup from before I tried to change. I do admit that I do not have the carbon towers or sway bars.
File Type: pdf
Djr8505 is offline
Old 04-22-2019, 08:51 AM
  #657
TLRacing
Frank Root's Avatar
It's posted up on the site. Here is the link - http://www.tlracing.com/ProdInfo/Fil...%2002.2019.pdf
I'm not sure about Barry's.
Old 04-23-2019, 10:51 AM
  #658
Trader Rating: 28 (100%+)
Frank, Couple questions with the setup.
1. I notice your running the soft mud guards, is that for flex and is the team using the different mudguards for tuning for tracks?
2. Also your running a rear ballast weight vs battery weight plate, when do you use one vs the other?
dbracn is offline
Old 04-25-2019, 09:39 AM
  #659
TLRacing
Frank Root's Avatar
1. The kit comes with SFT (soft) mudguards, and I've generally preferred those in testing. I admittedly haven't retested stiffezel guards recently. Some drivers are liking them though, so I'd say they're worth a try.
2. As the grip comes up, I generally move the weight forward in the car, removing the brass C block and going to the weight under the battery. I also tend to increase total weight as the grip increases.
Old 04-25-2019, 12:57 PM
  #660
Hey Frank,
About your setup, what does adding the +2mm shock tower and then increasing the shock stroke by 2mm do for you. This is very confusing, as it seems like they offset each other outside of raising the CG a tiny bit.
Hommerxxx is offline
