Like Tree886Likes
TLR 22 5.0
Old 03-08-2019, 03:46 PM
  #496
RazorRC's Avatar
Originally Posted by Frank Root
Everything is sorted for production, everything should be in stock later this month or early next month.
Any plans for longer front shock bodies or shock shafts when the +2 shock towers come out?
RazorRC is offline
Old 03-08-2019, 07:06 PM
  #497
Trader Rating: 15 (100%+)
Suggested starting gearing for 6.5 at OCRC.
trigger is offline
Old 03-08-2019, 08:18 PM
  #498
Originally Posted by I_NeedBigDrink
I'm also curious about this, I assume the ballcup pliers mentioned some pages back can be used for both installing and removing them. I just haven't bothered adjusting them since the initial build :P
I've found that the handle end of a shock wrench works extremely well for installing them. Just place one handle on top of the ballcup, and the other under the carrier, then apply just enough pressure until the ballcup pops into place. The textured finish helps to hold the ballcup in place (well, unless you happen to have a shock wrench with a smooth finish...the Tekno shock wrench has a textured finish).
thirtydaZe and I_NeedBigDrink like this.
Panther6834 is online now
Old 03-08-2019, 10:10 PM
  #499
Hey guys, could someone tell me if TLR4166 titanium shock mounts will work with the 5.0?
Thanks.
SLIPPERY76 is offline
Old 03-09-2019, 06:37 AM
  #500
Thanks.
I don't know...but, I do know that Lunsford offers Ti shock mounts for the 22 5.0:
Lunsford Racing Ti Shock Mounts
They also have Ti screws, turnbuckles, King pins, etc.
Old 03-09-2019, 09:06 AM
  #501
schirmann433's Avatar
I absolutely love this car. By far the best car out of the box without any fancy upgrades (yet) I have ever driven. Itís very planted and a point and shoot kind of acceleration. I was able to be super consistent with it the first night of racing. Canít wait to get more laps on this thing.
schirmann433 is offline
Old 03-09-2019, 09:23 AM
  #502
thirtydaZe's Avatar
Trader Rating: 39 (100%+)
Thanks.
horizon has 22 5.0 Ti specific standoffs.
thirtydaZe is offline
Old 03-10-2019, 12:20 PM
  #503
Trader Rating: 21 (100%+)
Haven't seen a lot of carpet setups going around, so I figured I'd share mine. Our local modified meta, although we cut our teeth primarily in on road, includes half a dozen past national champions at any given race.
A note that camber/toe on the sheet are all measured ball cup-to-ball cup (just like the manual). Due to imperfections in wheels, tires, and any suspension slop I have found it more consistent to measure these setting this way.
Stock A-main:
Mod A-Main:
If you have any questions, just let me know. The car is a fantastic improvement on the 4.0
File Type: pdf
peter_robinson is offline
Old 03-10-2019, 12:46 PM
  #504
thirtydaZe's Avatar
REAR CAMBER BLOCK, BLACK, W/INSERTS: 22 4.0
TLR334051
http://www.tlracing.com/Products/Default.aspx?ProdID=TLR334051
Is this 5.0 compatible?
Old 03-10-2019, 03:19 PM
  #505
Here are the some club racing results from today. Although I didn't win I consider a personal achievement of mine that this being the second week of me racing this buggy that I fell within a lap of the fastest 17.5 racers at our local track. This buggy is incredibly easy for me to drive consistently. The biggest times that I had trouble was dealing with traffic on the track.
Djr8505 is offline
Old 03-10-2019, 03:50 PM
  #506
R/C Tech Elite Member
I_NeedBigDrink's Avatar
So far going to steel outdrives has fixed my problem with the thrust bearing. Will update to see if it holds up after some more practice days.
I_NeedBigDrink is offline
Old 03-11-2019, 05:02 AM
  #507
psycho02's Avatar
Trader Rating: 14 (100%+)
What effect does it have on the car to add or subtract shims in the front?
psycho02 is offline
Old 03-11-2019, 05:37 AM
  #508
It depends on which shims your talking about. The shims in the front that control the height of the front mounting block controls roll center of the buggy. There are also shims on your spindles that control the track width of the buggy.
Djr8505 is offline
Old 03-11-2019, 05:56 AM
  #509
Trader Rating: 380 (99%+)
TLR334051
Yes it does!
thirtydaZe likes this.
jonski is offline
Old 03-11-2019, 06:03 AM
  #510
psycho02's Avatar
the ones that control the height of the front mounting block. More shims does??? Less shims does???
psycho02 is offline
