Like Tree806Likes
TLR 22 5.0
Old 01-28-2019, 01:25 AM
  #271
psycho02's Avatar
Trader Rating: 14 (100%+)
Originally Posted by SLIPPERY76
Anyone else read that they where switching back to the 4.0 shocks at the reedy race? Anyone shed some light?
Looks like 5.0 shocks to me. I think the other guys were testing aluminum caps on the new shocks.
psycho02 is offline
Old 01-28-2019, 05:53 AM
  #272
Originally Posted by Anthony.L
Anyone else notice the 5.0 AC slipped from late Feb until early April...
Yeah, just saw that on Amain this morning...WTF happened? Was already going to be a really late Feb birthday present as it was, now I'll have to wait even longer? No bueno, TLR
Phugazi is offline
Old 01-28-2019, 06:41 AM
  #273
Last I read is that they were having problems with the gear diff design and weren't happy with it. So they were holding off until they get it right instead of shipping something bad.
platgof likes this.
timski346 is offline
Old 01-28-2019, 07:34 AM
  #274
Ah, seems like an acceptable excuse...I'll allow it! I'd rather wait and have a better product. Good call TLR!
Pistol123 likes this.
Phugazi is offline
Old 01-28-2019, 03:26 PM
  #275
Has anyone had issues with their shocks leaking? Mine looked like this after just 2 days of practice... No bueno. I've seen this happen before where after the initial build shock swill leak until the seals swell(*cough* Tekno *cough), which is fine. I fully re-lubed all the seals and rebuilt them in hopes such is the case. Just weird, as my G2 shocks never did this, even with new seals(granted this is an entirely new system).
mtbwrench is offline
Old 01-28-2019, 04:38 PM
  #276
so I know this is asking alot but is there a chart somewhere that shows what crosses over from the 4.0 to 5.0. I can go back and forth between both manuals just looking for a shortcut. does the 5.0 use the same front bulkhead as the 4.0. also the shock towers look the same is it just the same front and rear shock towers as the 4.0 but in stiffizell.
walter white is offline
Old 01-28-2019, 04:51 PM
  #277
tony montana's Avatar
Trader Rating: 76 (100%+)
Front shock tower is different, front bulkhead is different. Rear shock tower I believe is the same just on stiffizell
tony montana is offline
Old 01-28-2019, 05:17 PM
  #278
RazorRC's Avatar
TLR shock seals are intentionally a little undersized when new so that when they swell up after a week they are the perfect size.
RazorRC is offline
Old 01-28-2019, 06:56 PM
  #279
We usually soak the seals in shock fluid before installing. Learned this tip from a Frank Root build video a few years back.
rbrownsr, RazorRC and mtbwrench like this.
DJPod is offline
Old 01-28-2019, 09:41 PM
  #280
I figured such was the case. I rebuilt them and doused the seals in oil before installation. It should be just fine by Saturday for my club race. I wonder if they're using the same seals, and it just takes longer for the seal to swell around the 3mm shaft?
edit: Nevermind, different part numbers.
Honestly, not much. There are a lot of little changes here and there, and they all add up to needing a lot of new parts.
From what I can see, there is 100% compatibility with:
  • The entire driveline, save for the waterfall on the trans case
  • Bearings
  • Turnbuckles
  • Rear shock tower/wing mount
  • Rear hubs, hexes
  • Front axles & shims
  • Front pivot, steel pivot brace & shims
  • Hinge pins & spacers
  • pills
  • wheels
  • springs
Partial compatibility:
  • ~80% of the hardware
  • Most of the ball studs
  • Arms (they fit, but different design)
I_NeedBigDrink likes this.
Old 01-29-2019, 10:24 AM
  #281
  • Bearings
  • Turnbuckles
  • Rear hubs, hexes
  • pills
  • wheels
  • springs
cool. really appreciate the reply.
Old 01-29-2019, 07:00 PM
  #282
platgof's Avatar
So, did anyone one race this sat, and how did you guys do????
platgof is offline
Old 01-30-2019, 07:12 AM
  #283
I think the problem is more significant than just waiting for seals to size correctly.
TLR drivers were running the 4.0 shocks last weekend, and that can't be a coincidence.
071crazy is offline
Old 01-30-2019, 07:43 AM
  #284
Trader Rating: 374 (99%+)
Frank stated that the 4.0 shocks on the 5.0 was nothing more than a tuning option. Some guys liked how that landed better than the G3 shocks. Nothing was said about any kind of leaking. I personally haven't hit the track with mine yet, but I am Saturday and can't wait.
jonski is offline
Old 01-30-2019, 08:32 AM
  #285
RazorRC's Avatar
I mean, believe what you want to believe. I have a 5.0 and the shocks definitely feel different on the track than the older shocks. I never felt there was anything wrong with the 4.0 shocks, so can’t say the new ones are better, they just have a different feel.
RazorRC is offline
