TLR 22 5.0
#259
Do these work with the standard steel cvd’s Or just the SR ones?
https://www.horizonhobby.com/lightwe...50-p-tlr232097
#260
#262
Have they said anything/any idea why the shock caps have been changed to composite over aluminum?
#264
Yeah, that and cost. But I have found that the plastic caps can slide over the retaining nut in a bad crash, so I put a 0.5mm washer on there before the nut. I do this also with my 4.0 and earlier kits because the nut would tend to scrape up the aluminum caps.
#265
Hey guys, other than the aluminium out drive saver is the SR diff the same as previous sr diffs?
#266
Are you sure the outdrives are different? I could’ve sworn the part numbers are the same in the manual.
#268
Not a 100%. In a video with Frank Root I'm pretty sure he mentions it. And it makes sense since the aluminum hub was revised for the spring. Often TLR keeps the same part numbers after a change.
#269
5.0 SR outdrive is TLR232094
4.0/3.0 SR outdrive is TLR232057
#270
Anyone else read that they where switching back to the 4.0 shocks at the reedy race? Anyone shed some light?
