TLR 22 5.0
#2641
Maybe good alternative to do the front end mod since the sct part is out of stock.
#2643
I've seen a lot of different setups using different height shock towers. Can anyone advise what the tuning impact is of going to a taller or shorter tower?
#2644
I have a couple sets of sct axels if anyone is looking and I have some front end mod blocks ready to go. Just message me
#2646
Or these, no pesky screw that can back out:
https://visionracing.net/product/tlr...um-front-axle/
#2647
Good afternoon,
I just replaced the aluminum chassis in my 5.0 elite and I actually gained 10 grams. I thought the carbon fiber chassis would be lighter. Was I wrong or is this typical?
#2649
Is carpet the ideal surface for the carbon chassis, or would high grip clay be appropriate as well?
#2650
I stopped running the 22 5.0 a while ago...but, if I remember correctly, the CF is best for astro/carpet, and the aluminum is best for dirt/clay. There's nothing preventing anyone from using one chassis type on the other surface type...but, remember that the CF & aluminum chassis are designed to flex differently.
#2651
R/C Tech Elite Member
Even extremely high grip (sealed) clay tracks aren't on par with say a black carpet track traction wise so I'd say leave the carbon chassis for carpet tracks. Having run on both, if you're running on a sealed clay track just run stiffezel pieces to minimize flex, run stiffer springs and lower the ride height a few mms and you should be golden.
#2652
Question about rear toe --
I'm putting together the parts to run the 22x-4 rear arms. If I run the Vision Racing Minus One C-Block, what should my pills be if I want to keep the same toe? Should I keep the same toe? I was running 0 in both C and D. Running on high grip packed clay.
#2653
C - Middle
D - 1 Out
D - 1 Out
#2654
c
block, 1 in
d block middle
block, 1 in
d block middle
