TLR 22 5.0
#2506
Does anyone know if a new carpet buggy is coming soon? My son is wanting to get into racing and our local track is a carpet track. If there is one coming soon I would like to wait and get it for him. If not then I guess I will need to go with an AE buggy since the carpet 5.0 was discontinued. Any input would be greatly appreciated.
#2507
Huh, this is interesting...
At Masters Of Dirt, Dakotah is running an AE Octalock Spur Gear. Less interesting is the aluminum Team Brood slipper plates.
The only reason i can think for doing that, is that he needed the additional gearing from the 87 tooth spur gear, and TLR only goes up to an 81 tooth spur. And that does look like the 87 tooth spur in that picture.
I know i have seen some of the factory TLR guys run the 74.1 center diff for the same reason, additional gearing options, in stock classes as well.
#2508
I ordered the V racing C block to use the 22x-4 arms. What is a good starting point for the pill settings for carpet?
#2510
Another interesting thing i noticed about Dakota's Masters of Dirt car.
Look at the rear shocks. They do not have the machined in notch around the base, denoting they are the 3.5mm shaft shock bodies, and you can clearly see the 3.5mm etching on the right hand shock.
It would appear he is running the 3.0mm shocks in the front, and the 3.5's in the rear. Be curious if anyone from TLR could confirm/explain why that would be ideal? As i would imagine it would slow down the liveliness of the rear end, substantially.
#2511
Switching focus to the front of his car, it is incredible to see just how..."hacked up", the front end of the car is.
Like i would expect that the parts would be a little more finely finished than they are. But no, the are straight up hacked. The end of the cars look like they were flat cut off, a cut off wheel. And the Spindles look like they were hacked into with a cutting wheel too, and then mildly cleaned up with a sanding drum.
I dont know why, but i would have expected the car to have some machined spindles on there, or parts that were more finely modified than that. But, i guess like many other real life race cars, it doesnt need to be pretty to work.
#2513
Yeah, very familiar with the front end mod. My shock is that on his car it is so roughly done. I would have expected his cars to be a little more..."put together" for lack of a better phrase. I am in the process of doing the same mod on my 5.0 now. And i am being absolutely meticulous with it. Trying to find ways that i can make the process easily repeatable, and consistent, and look likes it is supposed to be that way, even looking at how to make some jigs, so i can make the parts at the track if i need to. So, when i see his hacked up like that, its just a bit shocking. Especially when people at TLR, like Frank Root, are picky about the clocking and alignment of nuts on shock towers so they look even. LOL!
#2514
I'll just buy the TLR Narrow Wheels...
#2517
#2518
Absolutely BRILLIANT spot! I didnt even catch that at all. But your absolutely right. The top looks smooth too. So, i wonder if he is getting a part without those holes molded in, or if he is simply taking some of the shavings from the sanding process, and mixing them with some CA glue to make it solid, and then drilling out the middle hole? Given the way the edges are kind of rounded over like they have been sanded down a bit, i am going to guess the later. Glue or epoxy the holes, then drill a new center location. Very interesting.
#2519
Haven't been able to find this answer via searching....
Wanting to get hub adjustability in a 5.0 AC carpet car. The VHA conversion comes with new arms, axles, bearings, etc. Do I need to use all of those items just to get some vertical adjustability, or can I buy just the hubs and inserts while keeping the existing arms, bearings, etc?
Thanks!!!
Thanks!!!
#2520
Thanks!!!
Thanks!!!
