Like Tree886Likes
TLR 22 5.0
Old 03-01-2022, 05:50 PM
  #2356
OffRoadJunkie's Avatar
any news on when the 22 5.0 will be updated? Wasn't the last update in 2019? That's as old as the Kyosho RB7.
OffRoadJunkie is offline
Old 03-02-2022, 08:33 PM
  #2357
TLR already missed their perfect release date of 2/22/22… I’d say you’ve got a bit to wait. Hopefully they’ll be ready by next indoor season? 🤞 Lol
thirtydaZe and OffRoadJunkie like this.
Bcollins82 is offline
Old 03-03-2022, 10:30 AM
  #2358
TurnNBurn's Avatar
Missed opportunity indeed.
I was about to say how ironic it was that AE officially announced their new 8th scale buggies instead, but the YouTube video actually dropped on the 23rd.
TurnNBurn is offline
Old 03-07-2022, 09:59 AM
  #2359
mes
I am positive it will drop the moment I start to build another 5.0, which should be soon... As someone who likes to build a really new kit sooner rather than later, I was not super stoked about getting another DCE, but after some batteries with a friend's car having the front end modification and a couple of set-up tweaks, I made my peace with it and decided not to wait for a new platform any longer.
mes is offline
Old 03-09-2022, 11:40 AM
  #2360
Did you also tried the rear end mod? What tweaks did you found useful?
Pancar_GER is offline
Old 03-10-2022, 12:30 AM
  #2361
mes
The owner of the vehicle tried the 22X-4 rear arms before and did not like it, and accordingly he had changed back to the standard arms. We minimized rear toe and increased anti-squat. Other than that, his basic settings were quite good.
mes is offline
Old 03-19-2022, 07:15 AM
  #2362
Roger H's Avatar
Trader Rating: 24 (100%+)
So what is the rear arm mod doing for the car?
Roger H is offline
Old 03-20-2022, 06:48 AM
  #2363
mes
I haven't tried it myself. The arms are longer, which in m book creates more corner speed and reduces traction. As the shock mounting positions are different, shock response will also change. Using the sway bar will require some additional work, but the lower and rear mounted sway bar should be more effective. Maybe someone who has tried it can chime in, on my part it is only theorizing based on experience with other cars.
mes is offline
Old 03-20-2022, 06:37 PM
  #2364
TRFHORNET's Avatar
what's this front end modification and what does it do?
TRFHORNET is offline
Old 03-21-2022, 06:48 AM
  #2365
Pistol123's Avatar
I think is using the VLA on the ftont arms to reduce the track and allow the use of AE wheels which would previously made thr track too wide and illegal.
Pistol123 is offline
Old 03-21-2022, 07:39 AM
  #2366
KINGZJ's Avatar
The vla does not change track width it only changes the pivot location
KINGZJ is offline
Old 03-21-2022, 08:28 AM
  #2367
Pistol123's Avatar
That's the official view, but I saw a post a couple of pages back where people are using the outer hole of the hub and the inner hole on the wishbone - it requires a bit of dremelling but allows the use of ae offset front wheels.
TLR 22 5.0
Old 03-21-2022, 09:44 AM
  #2368
TLR 22 5.0
It also requires the use of the unobtanium SCT Spindle. Which, is available in Aftermarket, thankfully.
Pistol123 likes this.
BigBuckORamma is offline
Old 03-24-2022, 12:07 PM
  #2369
Trader Rating: 29 (100%+)
Who makes them other than exotek? The EXO2013 spindles are slightly wider than the TLR SCT 3.0. I measured my SCT axles at 4.75mm while the EXO says theirs are 5mm.
NocturnalNitro is offline
Old 03-24-2022, 03:52 PM
  #2370
Exotek is all i am aware of.
You can run shims on the backside of the Exotek spindle under the set screw to get it to the correct width.
