Like Tree879Likes
TLR 22 5.0
Old 01-24-2022, 10:41 PM
  #2341
fifi's Avatar
On some setup sheet Ryan C. is using gen II rear hub. Anybody knows why? The difference with the actual one.
fifi is offline
Old 01-26-2022, 06:29 PM
  #2342
Do the Jconcepts Swaggers 2.2 Pre-Mounted 2WD front Buggy Carpet Tires (JCO3137-101011) fit directly onto the 5.0 ? or is the "front end mod" that I keep hearing about necessary to make these work..
OnCam is offline
Old 01-26-2022, 08:08 PM
  #2343
Those pre mounts require the front end mod to work.
OnCam likes this.
Bcollins82 is offline
Old 02-06-2022, 05:54 PM
  #2344
fifi's Avatar
I did the front end mod to fit AE wheels.
My problem it sometimes lock up at front full compression.
Any idea?
fifi is offline
Old 02-06-2022, 06:34 PM
  #2345
Any idea?
The tires wonít rotate when tightened all the way? If thatís what youíre asking, I dremel off some material on the rear of the wheel. You can also run 22SCT 3.0 front axles.
Old 02-07-2022, 04:07 AM
  #2346
elex300's Avatar
Trader Rating: 110 (100%+)
You should be running the sct front axles when doing the front end mod.
elex300 is offline
Old 02-07-2022, 04:17 AM
  #2347
Yeah, Iíll jump right on that in mid May when they finally come back in stock.
Old 02-07-2022, 08:13 AM
  #2348
Trader Rating: 280 (100%+)
I've been using Associated front axles on mine...fit perfect. (SCT-5M)
Andy Koback is offline
Old 02-07-2022, 11:20 AM
  #2349
Whatís the measurement from shoulder to wheel mounting surface?
Old 02-07-2022, 12:45 PM
  #2350
From the shoulder that rests against the bearing to the back of the hex, there's 3 different off-sets. 2mm, 4mm, and 6mm. These were all used on the B5, T5, and SC5M.
Old 02-07-2022, 02:36 PM
  #2351
fifi's Avatar
I am running 22sct 3.0 front axles.
fifi is offline
Old 02-08-2022, 05:20 PM
  #2352
elex300's Avatar
Exotek makes sct axles as well. They are nice! EXO2013
elex300 is offline
Old 02-14-2022, 01:43 PM
  #2353
I have been wanting to try the standard carbon tower on my setup but standard carbon towers are out of stock for couple more weeks. I was thinking wouldn't running the 2mm longer shock ends with the +2mm tower be the same thing as running normal ends with a standard tower. To me either way you are playing with 2mm of droop and up travel.
fantomdude is offline
Old 02-14-2022, 07:15 PM
  #2354
The only other difference you would have by doing that would be that the center of gravity would be a little higher in the car due to the shock setting 2 mm higher as well. If you are real interested in trying the standard towers you might be able to get away with using composite. If you don't like the setup you're not out of a lot of money for the carbon fiber shock towers
r schowengerdt is offline
Old 02-14-2022, 07:21 PM
  #2355
Vision Racing RC makes -2 shock towers for the 22 5.0.
They also make a conversion to use the 22x-4 rear arms.
B-woo is online now
