Like Tree886Likes
TLR 22 5.0
Old 01-07-2022, 09:38 PM
  #2311
TurnNBurn's Avatar
Iím curious, because Iíve seen talk of this mod for months now. Is this mainly for carpet, because I recall some people mention that using the 22X-4 rear arms is not for all situations.
Itís also interesting that the AC seems to be discontinued. I would speculate that we will either see an AC Elite, or maybe a mild refresh to the 22 (not a 6.0) that begins with all the secret goodies Frank, Gil Jr. and the crew have been working on to improve the buggy on carpet these past few years. I HOPE that means we finally get an easy access diff as well.
mes and Chadleek like this.
TurnNBurn is offline
Old 01-08-2022, 12:10 AM
  #2312
mes
One can only wonder what amount of changes would be required to make it an 22 6.0 AC instead of an 5.0 AC2. There has been talk of testing different chassis lengths, the front and rear suspension modifications in plain sight, the rear sway bar mount, the quick access diff we all want to have, revised shock internals and domed caps... Did I forget anything other than the flux capacitor?
If I was to dream about a new platform, it would have a smaller front pivot and ballraced quick access sway bars similar to those on touring cars...
mes is offline
Old 01-08-2022, 02:43 PM
  #2313
TurnNBurn's Avatar
I know about the domed caps (which I would expect they might offer composite versions in an updated kit?), but after the V2 seal package update, what more would they revise? The shocks seem awesome to me with the V2ís and thin pistons. Iím still using the old aluminum caps though.
Old 01-08-2022, 04:49 PM
  #2314
So I'm looking at building a 17.5 buggy for carpet. I can still find the AC kit on Amazon for $269. I know it's discontinued, so how long can I still buy spare parts for it after? Going to be my only car just to keep me busy when I'm not playing with real cars. I don't want to upgrade a chassis every year just to play for a few months.
MINIz guy is offline
Old 01-08-2022, 07:23 PM
  #2315
TurnNBurn's Avatar
The 5.0 platform is still the ďcurrent carĒ, and the AC was just a variation of it. As long as the Elite and DC Roller are still available for it, no worries - all the parts unique to the AC are still optionals for the platform. Even if the other two kits get discontinued, TLR/Horizon maintains a policy of keeping spares stocked for about two years after the fact.
MINIz guy likes this.
Old 01-08-2022, 11:11 PM
  #2316
mes
That's already a fully revised package vs. the 5.0. The only additional upgrade I could think of would be shock bodies manufactured using the method Ryan Dunford described in one of the 8ight XT videos, which seem to be smoother again.
While I preferrred the plastic shock caps over aluminum on the Yokomo cars, I am not sure if they shouldn't just stick to the current domed caps. Plastic caps would be another subproject requiring durability testing and an expensive mold, and most TLR customers would prefer the alu parts anyway.
mes is offline
Old 01-09-2022, 11:27 AM
  #2317
Hi all,
This is a 4 screws access gearboxe conversion kit still available until the 6.0 comes and after...
​​​​Specs :
-Direct replacement with stock parts,
-durable laser sintered (SLS) white Polyamid 12 powder can be spray painted by thin layers externaly only (rit dying not recommended),
-only 4 screws diff and idler removal,
-camber block fit upside down with stock ball stud seat,
-stock shock tower and motor location,
-insert nut x 8pcs,
-diff height by 0, 0.75, 1.50, 2.25, 3.00, 3.75, 4.50mm,
-lowered profile (idler lowered),
-RR sway bar mount included.
The +4.5 inserts set makes the car faster than stock +3.5 on high grip @14mm riding height due to better CVDs alignment.
Each kit includes :
-LH CASE,
-RH CASE,
-DIFF COVER,
-TOP SHAFT SPACER,
-DIFF INSERT SET (2) x4pcs,
-IDLER SLIDER,
-M3 CAPTURED NUT x8pcs,
-2 PARTS RR SWAY BAR MOUNT,
-M2.5 CAPTURED NUT x1pc,
-SCREW SET,
-BASIC MANUAL,
-AZ STICKERS.
Kit manualy prepared in order to be ready to fit : deburred, pre-drilled by 2.2, 3 & 3.2mm, insert nuts placed.
I can't post photos here yet then check or/and join me on FB if interrested.
Regards.
kjohnsiii likes this.
azizouh is offline
Old 01-11-2022, 07:03 PM
  #2318
Trader Rating: 42 (100%+)
Smith90 is offline
Old 01-14-2022, 02:49 PM
  #2319
artwork's Avatar
Trader Rating: 88 (100%+)
Designed an oversized Shock Bushing that takes up some of the slop in the plastic or metal shock top. This will work for the 22 and 22x4 cars. Incase anyone wants to print some.
TLR 22 Shock Bushing - Oversized by artw0rk - Thingiverse
RBLove likes this.
artwork is offline
Old 01-17-2022, 09:21 AM
  #2320
stupid question,
where would one find the rear hexes in the 4.5, 5.0, 5.5 & 6.0 sizes??? The manuals only seem to list the STD that come in the kit.
Evoking1230 is offline
Old 01-17-2022, 09:37 AM
  #2321
SCRAFAN's Avatar
Trader Rating: 22 (100%+)
I think if you look at most of the suppliers A Main, Horizon Etc, you can find them. they don't have to be TLR specific just a 12mm clamping style hex.
Evoking1230 likes this.
SCRAFAN is offline
Old 01-17-2022, 10:10 AM
  #2322
for those running the DC Roller on carpet, are you going off the AC for a base setup or is something else floating out there?
Thanks!
Old 01-17-2022, 10:15 AM
  #2323
Must of been using the wrong search term, I found actual TLR ones
Old 01-17-2022, 10:37 AM
  #2324
Trader Rating: 280 (100%+)
I'm using Asoc.
Andy Koback is offline
Old 01-20-2022, 12:54 PM
  #2325
Any word on the 22 6.0 coming out?
Dmill78 is offline
