Like Tree196Likes
TLR 22 5.0
Old 01-18-2019, 10:45 PM
  #211
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Picked mine up last nite, finished it last nite, ran it today.
It's really good.
SR kit
Here's my issue with 17.5 class, I'm very competitive in the Sportsman class, many wins and podiums.
So I'm in the Expert class, I get that.
Here in So Cal, that's a HUGE leap. 1 second a lap difference between the top of each class.
I'm moving out of the way every couple laps, throws off timing, now I'm that guy that crashes and messes up someone else' s good run as well as mine.
Don't really expect to win, aint gonna happen, no biggie
I hear, not to worry, hold your line, you'll only get faster running with the faster guys...
So I'm an in betweener, I call it Sportspert lol.
I prep and maintain my car like a Sportsman lol
I miss racing with the Sportsmen cuz it's always a battle but I know it's not cool to be that guy.
There, vented, all better now.
F N CUDA is offline
Old 01-19-2019, 12:13 AM
  #212
RazorRC's Avatar
Unboxing video posted for those of you curious what's in the box:
RazorRC is offline
Old 01-19-2019, 04:34 AM
  #213
Got a few laps in on another drivers fresh 5.0 SR. I liked how stable it was in the sweeper and it took the tight corners like a champ. I was expecting it to slap a bit with the smaller shock shafts but didn't really notice it get unsettled on the big jumps, lands good. I've had a 4.0 sr and now a b6.1d, and the 5.0 felt like a mix of the best straits of both. Very planted and great steering. Overall impressed with the limited time on it. He said he built it with minor changes from his experience with his 4.0 so it was not kit setup exact.
trf211 is offline
Old 01-19-2019, 05:44 AM
  #214
https://youtu.be/7cjPsMOFgnc
Differential differential and a lighter body what is the real difference between the SR and the AC models. Wondering if I should maybe just get the SR and replace the composite outdrives and differential with a gear diff
Djr8505 is offline
Old 01-19-2019, 06:04 AM
  #215
Not sure but presume the ac will come with the raised roll centre front and rear along with anti roll bars.
Pistol123 is offline
Old 01-19-2019, 06:43 AM
  #216
So it will be more than just slap in a gear diff and go for carpet.
Djr8505 is offline
Old 01-19-2019, 06:50 AM
  #217
F N CUDA's Avatar
carpet car has lots of differences, shock pistons and springs, gear diff, sway bars, stiff rear arms, narrow front wheels, plus 3mm hubs, plus 3.5 mm diff height, wider front wing...
Franks video describing these kits is really good
just watched it again since just getting new car
F N CUDA is offline
Old 01-20-2019, 03:40 PM
  #218
tony montana's Avatar
Trader Rating: 71 (100%+)
If your on the fence about getting a 5.0 do it asap! What a great job from the whole team
nulk1 likes this.
tony montana is offline
Old 01-20-2019, 04:01 PM
  #219
The new longer 25T aluminum servo arm isn't available. I built with the plastic one but don't think it will last long. Anyone got any time on the plastic arm?
Roken is offline
Old 01-20-2019, 04:16 PM
  #220
Ran quite a few packs with the plastic arm today and had no issues
Old 01-21-2019, 09:29 AM
  #221
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Roken View Post
We need a blank setup sheet. None in kits.
I sent it to the web team, should be on the site before too long.
Originally Posted by Phil250 View Post
Does anyone know if the front and rear arms are the same as the 4.0?
They are different. 5.0 arms are in stock. 4.0 arms can fit with some minor dremel work.
The molded ones have actually been very durable. We are working to get the aluminum version into stock asap, however.
Frank Root is offline
Old 01-21-2019, 12:32 PM
  #222
Just an FYI: There is a blank editable, kit setup, and a few others posted for the 5.0 on TLR's site.
mtbwrench is offline
Old 01-21-2019, 01:04 PM
  #223
Davidka's Avatar
Trader Rating: 83 (100%+)
FWIW, I have only ever run molded servo arms in my 2wd buggy (AE & TLR), and I have never had one fail.
Davidka is offline
Old 01-21-2019, 03:35 PM
  #224
why have you only used the molded servo arms? I'm just curious that's all.
MaX-D is offline
Old 01-21-2019, 03:40 PM
  #225
I would assume because that's what comes in the kits?
cjcoffroad is offline
