Like Tree886Likes
TLR 22 5.0
Old 11-23-2021, 04:55 PM
  #2221
Trader Rating: 23 (100%+)
RazorRC likes this.
Rhett McNair is offline
Old 11-23-2021, 05:03 PM
  #2222
This is how I did it, you will need shorter turnbuckles for the camber and steering. I was told this weekend that other guys are using the 22sct 3.0 axles. I just ordered a set to see.
Old 11-23-2021, 05:12 PM
  #2223
Trader Rating: 27 (100%+)
Originally Posted by Rhett McNair
Thanks Rhett. That helps.
Is the that one-hole arm the new part? I assume that caster block is also new? That would explain how they handle the offset.
Still prototype or it released?
MDawson is offline
Old 11-23-2021, 05:16 PM
  #2224
Originally Posted by Andy Koback
How much wider overall are we talking?
Rhetts post cleared up missing pieces.
I dont have any AE/YOK fronts around but this is some idea between the TLR and X-ray.
Simply
TLR NARROW FRONT
- inside track width (inside tire to tire) about 200mm
- outside track width (outside tire to outside tire) about 240mm
XRAY FRONT
-inside track width (inside tire to tire) about 210mm
- outside track width (outside tire to outside tire) about 250mm
Andy Koback likes this.
MDawson is offline
Old 11-23-2021, 05:21 PM
  #2225
Same parts just dremeled
MDawson likes this.
Old 11-23-2021, 05:30 PM
  #2226
Rhett,
For the arm mounted on the car - it has the single hole outside vs. the two hole outside arm.
Which one are you running with this revised front end?
MDawson is offline
Old 11-23-2021, 05:34 PM
  #2227
Rhett,
single hole
Cut off the outer hole on the arm. Cut off the inner hole of the caster block
Old 11-23-2021, 05:47 PM
  #2228
single hole
Perfect!
MDawson is offline
Old 11-23-2021, 05:53 PM
  #2229
Ewww, bad lighting.
I have always ran the front end with the inside arm hole and inside caster hole while using the TLR Narrow fronts.
Ill have to try Rhetts handy work and see how the front end looks using the offset wheels.
Thank Rhett.
MDawson is offline
Old 11-23-2021, 10:45 PM
  #2230
Trader Rating: 84 (100%+)
You need to run the upper link on the outside hole on chub when doing this mod to retain the same link geometry
MDawson likes this.
jeff jenkins is offline
Old 11-24-2021, 07:00 AM
  #2231
Where did you get that front wing?
Can anyone clarify for me the difference and when its needed to run the low wing pictured above and the high wing that mounts on the shock tower (AC)? New to this front wing stuff.
Thanks!
Evoking1230 is offline
Old 11-24-2021, 07:31 AM
  #2232
Originally Posted by Alexv2024
If it makes you guys feel better (or worse haha) at the last 5-6 big races TLR 2ws have been running AE off set front wheels. Dakota and other team drivers.
So get those AE 2ws for carpet so you can be on the right offset and have quick access diffs, and a wide variety of chassis arm and pivot widths/lengths who knows how long till TLR releases the next car...
Forgive my ignorance, but what is the difference between TLR and AE offsets? I know the fronts that come with the AC are the "slim" ones. I tried looking on amain and tlr/ae sites for a better explanation but I guess I missed it lol.
Old 11-24-2021, 07:56 AM
  #2233
Thanks!
MDawson and Evoking1230 like this.
Old 11-24-2021, 08:02 AM
  #2234
Thanks!
Is the low wing preferred now on carpet over the high wing??? Just trying to understand when to use each.
Old 11-24-2021, 08:08 AM
  #2235
mes
​​​​​​On traditional 22 wheels, he position of the wheel hex is close to the outer side of the wheel (similar to current 4WD buggies), on virtually everyone else's wheels (Kyosho used such wheels before AE iirc) the hex is closer to the centerline.
Evoking1230 and RazorRC like this.
mes is offline
