Like Tree886Likes
TLR 22 5.0
Old 06-04-2021, 11:44 AM
  #2146
Lightweight electronics (servo, esc and motor) can add up to a hefty chunk of weight also. For high bite tracks the lower center of gravity helps quite a bit with corner speed. Ive run a futaba corless shorty servo in 2wd and 4wd for years with great results, plus its about 20g lighter than most aluminum case servos. I do run plastic servo arms to act as a servo saver but I've only broken one or two in the past 10 years or so, servos still going strong.
dcerven94 is offline
Old 06-19-2021, 06:04 PM
  #2147
wfo
wfo's Avatar
Location: SO. CAL. Thunder alley, revelation raceway The Dirt -Perris RIP OCRC
I’ve been messing around with the front kick shims kit has it at 3mm, what do u guys run on high bite clay with medium size jumps. How are the brass kick shims? Thanks
wfo is offline
Old 07-25-2021, 03:02 AM
  #2148
Originally Posted by wfo
Has anyone pressed in new pins in their TLR cvaís , if so what size did you use? Thanks
Hey, did you find out anything more? Is it the dogbone pin, where axle meets diff outdrive you mean?
I measured mine and found they are 2.4mm, so 2.5mm which you can get many places will be to big, I think.
nils10 is offline
Old 07-25-2021, 09:32 PM
  #2149
wfo
wfo's Avatar
I’m going to try a 5-S-N seam clamp, used for roofing. The Mugen bone tool was to big for the 1/10 dogbone . Yeah the 2.5 pins look like the ones to use.
wfo is offline
Old 07-25-2021, 10:25 PM
  #2150
Trader Rating: 19 (100%+)
will we see an updated carpet car or at least a quick access diff retrofit anytime soon?
tnt2671 is offline
Old 07-27-2021, 06:01 AM
  #2151
RynoRC's Avatar
Outside of diff access, what do "we" want in a 22-6.0 AC?
RynoRC is offline
Old 07-27-2021, 08:24 AM
  #2152
Trader Rating: 282 (100%+)
More threaded area on front axles. Would like to run different wheels. 10mm threaded length would be great.
Andy Koback is online now
Old 07-27-2021, 09:44 AM
  #2153
TurnNBurn's Avatar
As 22X-4 rear arm swaps seem to have been a bit popular (havenít tried myself), perhaps dedicated 22 rear arms to match the geometry/spacing/whatever ďmagicĒ the arms seem to do for the buggy are in order?
Oh, and maybe revised G3ís with composite versions of the domed caps (I suppose the aluminum ones will always be an option part)?
That being said, I donít necessarily think the 22 needs a ď6.0Ē upgrade. With little refinements like this, plus the top secret carpet/Astro changes theyíve been working on for over a year, Iím guessing they could get away with a ď5.1Ē that 5.0 owners could upgrade to - or heck, just call it a 22X for consistency across the buggy line, hehe. I believe that itís gotten to the point that we donít need a whole new buggy to remain competitive. Iíd be happy with an available upgrade kit or parts list.
RCDaddy2105 likes this.
TurnNBurn is offline
Old 07-27-2021, 10:16 AM
  #2154
The 22X-4 rear arms are not for everywhere according to Ryan Cavalieri. It is also personal preference.
Chris Reilly is offline
Old 07-27-2021, 10:31 AM
  #2155
RynoRC's Avatar
Wasn't aware there was top secret AC upgrades in the works. Will keep my eye out! Good suggestions.
RazorRC likes this.
RynoRC is offline
Old 07-27-2021, 01:31 PM
  #2156
just the quick access diff , besides that I love my ac
Andy Koback likes this.
tnt2671 is offline
Old 07-27-2021, 06:10 PM
  #2157
TurnNBurn's Avatar
Makes sense, particularly when you are adapting a part from one buggy meant for another. Like I said, maybe the 22X-4ís arm design just needs to be refined to better work with the 22ís suspension geometry while still providing the benefit that led to experimenting with the arms in the first place. 🙂
Oh itís been lurking in the shadows for at least a year. Frank mentioned it most prominently during last yearís live stream with Thomas how heís been working with Gil Jr. in his consulting role to make the 22 better in very high bite situations (i.e. carpet), so I hope they are close to revealing something soon!
Old 07-28-2021, 12:30 AM
  #2158
the 22 ac is a great carpet car and at the current price the best value out there , every bit as good as the latest ae's and others in my experience the killer is the really diff access and to a less extent wheel compatibility these is the only major negatives that I see.
tnt2671 is offline
Old 07-29-2021, 10:27 PM
  #2159
frank or any other losi insiders on this forum? will we see a retrofit diff setup? im in the market for another couple buggies and would like to stay 22 if there's something coming down the pipe
tnt2671 is offline
Old 07-30-2021, 07:08 PM
  #2160
There were no TLR's left here. All switched to AE, Xray, Schumacher and Yokomo. No one could make the car work. I know no one was doing what Frank was doing to make it work. So maybe that is why. the last guy switched from TLR and immediately went up 1 to 2 mains with the schumacher car. I believe the TLR can do it but you have to do some work to get it there. you don't have to do the work on the others
