Like Tree886Likes
TLR 22 5.0
Old 01-22-2021, 05:54 AM
  #2011
Originally Posted by ray4624
how bad is it rubbing?
it's barely rubbing,I was thinking shaving the link to the servo horn but would like to get alumlinum horn but it will definitely rub
Eddosi1978 is offline
Old 01-22-2021, 06:10 AM
  #2012
Originally Posted by Eddosi1978
it's barely rubbing,I was thinking shaving the link to the servo horn but would like to get aluminum horn but it will definitely rub
You can remove a small amount of material from the bulkhead. Get a horn specifically for the 22 5.0 and you won't have any issues.
waitwhat is offline
Old 01-22-2021, 06:19 AM
  #2013
thanks I'll go ahead and do that
Old 01-22-2021, 09:22 AM
  #2014
TurnNBurn's Avatar
IIRC, Savox servos are based off of Aeronautical designs, whose output shaft locations are slightly different from the typical surface design. This may be the root of your problem. I know it created a bit of an issue in the 22X-4 when it released, and TLR eventually updated the servo mount kit for that. Assuming heís still sponsored by Savox, now that Ryan Cavalieri is withTLR, I would assume that they have, or soon will update the 22ís servo mount kits to accommodate aero servos accordingly.
TurnNBurn is offline
Old 01-22-2021, 09:43 AM
  #2015
RazorRC's Avatar
I did not add spacers and it still rub.
Interesting. I ran that servo in my 22 5.0SR and it did not rub with the kit servo horn. It was very close, but did not hit.
RazorRC is offline
Old 01-22-2021, 11:19 AM
  #2016
https://www.youtube.com/watch?v=NxdF9_SuKJU
let me clarify that, i don't think it rubs but it is so close. I have to stare at it long enough to see. Sorry I was over exaggerated lol. Yes I seen this video and it definitely helped with alot.thanks
Old 01-22-2021, 03:59 PM
  #2017
D_zeller's Avatar
I run a savox 158tg in my elite, with the aluminum horn for the 5.0 with no issues. Been running for me for 6 months now.
not sure what the root of the problem is, or if itís really rubbing. Mines def very close but it clears.
D_zeller is offline
Old 01-22-2021, 04:51 PM
  #2018
opposite for me and another guy Netcruzer on YouTube,I have a aluminum servo horn from associated and it rubbed and stock horn didn't rub but very close, gonna order the TLR horn TLR331033 that's for the actual buggy and hope the best
Old 01-22-2021, 07:16 PM
  #2019
opposite for me and another guy Netcruzer on YouTube, I have a aluminum servo horn from associated and it rubbed and stock horn didn't rub but very close, gonna order the TLR horn TLR331033 that's for the actual buggy and hope the best
That is the problem. A servo horn can be a generic item that is interchangeable between cars, but most cars now a days have a horn that is designed specifically for that car and only a horn of the exact dimensions as the stock servo horn will work. An AE horn is not designed for the 22 5.0. Changing the horn to something that wasn't designed to be exactly the same will change steering response. With so many options for servos no car manufacture can give exact spacing for every servo, so it is very important to spend the time to ensure the servo is in the exact right spot. Introducing another variable by switching to a different horn you probably will never get the steering to work correctly.
Pistol123 and D_zeller like this.
waitwhat is offline
Old 01-25-2021, 04:38 PM
  #2020
Ran into a problem after build was complete, rear suspension seems like it's binding not working properly. I checked to see if it was arms binding by taking off shocks and arms are free but it's when I install the shocks and it seems to bind. Trying to explain as best I can,when I press down the rear suspension it goes back up but binding at the same time,like I would have to bring it up by hand.If anyone to help it would be great. Thanks
Old 01-25-2021, 05:13 PM
  #2021
Default UPDATE:
Update, figured out what it was, shocks were bolted to tight which caused binding, new to me because I'm used to Associated and I used to tighten them without problems.
Old 01-26-2021, 07:04 PM
  #2022
dirtdog's Avatar
Trader Rating: 21 (100%+)
Savox servo and aluminum 22 5.0 servo horn will rub the bulk head. You have to shave the bulkhead. -Tim
dirtdog is offline
Old 01-27-2021, 10:49 AM
  #2023
D_zeller's Avatar
I didnít have to, mine clears it somehow. 😶🤷🏼‍♂️
D_zeller is offline
Old 01-27-2021, 04:27 PM
  #2024
Trader Rating: 65 (100%+)
Edit: In response to someone asking about 3.0 shock shaft and body setup...
They suck balls IMO. The 3.0 setup doesn't have enough pack for me in either dirt or carpet. Save your money and stay with 3.5 if you like some decent dampening. If you like to chassis slap and run super high oil to prevent, then run the 3.0s. This of course is just my opinion. I like a car with dampening, not something that blows through its shock travel...
Antimullet is offline
Old 01-27-2021, 05:07 PM
  #2025
Apexin's Avatar
Mine clears with the Savox servo but just barely. I now have a Protek 160 and it clears no problem.
Apexin is offline
