Like Tree833Likes
TLR 22 5.0
Old 03-08-2020, 05:21 PM
  #1681
Originally Posted by Jeff H
I just finished building the same kit. I would disconnect the shocks completely and try cycling the suspension without them to see if it moves freely. And try the shocks without them mounted. The shocks with the including springs and fluid should move pretty easily as they are pretty soft.
I noticed my right front suspension was binding too. It ended up being the actual hub carrier screws being too tight.
Jeff H and NYURDRMS like this.
K_Esp19 is offline
Old 03-08-2020, 05:30 PM
  #1682
Originally Posted by TurnNBurn
On the gearing, is that person also running an R-Spec? Remember that those motors should be geared down about 10% from a typical stock motor.
Yes, he is. I'm using his setup as a base for my astroturf setup.
K_Esp19 is offline
Old 03-08-2020, 05:47 PM
  #1683
My front hubs were were pretty tight too. I backed them out a couple turns but am hoping it loosens up more after running it.
Jeff H is offline
Old 03-08-2020, 05:49 PM
  #1684
Originally Posted by NYURDRMS
Hey Guys,
New to the hobby and I just got done building my TLR 22 5.0. It seems the front suspension is way too tight. In fact when pushed down, it does not spring back up, I have to actually manually pull the wheels back down. I assume I may have filled the shocks incorrectly. Any advice, before I start breaking the front end back down?
Thanks,
Chad
So I think I found the problem. There are two screws on each side, front and back on the wheel side of the suspension where it connects the arm to the wheel hub. I loosened those screws on each side and that loosened the suspension to be free.
dcerven94 and Jeff H like this.
NYURDRMS is offline
Old 03-10-2020, 02:10 PM
  #1685
DesertRat's Avatar
Does the new gear diff fit in the 22 4.0 gear case?
DesertRat is offline
Old 03-10-2020, 03:28 PM
  #1686
Its a good idea to check for free movement of the suspension every time the shocks are off
dcerven94 is offline
Old 03-10-2020, 05:00 PM
  #1687
Yes.
aurell is offline
Old 03-10-2020, 08:03 PM
  #1688
Just ordered an elite kit, gonna be running 17.5. Some how got on trinityís site and got an x-factor that was in stock lol. Iíll build it like it is, then probably get some transmission ceramics and the cut gears.
I went ahead and picked up a brass c block and several different AE v1 springs to get me going.
Iím stoked, this is my first Losi 2 wheel after having every associated 2wheel b4-b6.1.
Jeff H likes this.
tacomaster is offline
Old 03-11-2020, 12:45 PM
  #1689
offroad dude's Avatar
Trader Rating: 31 (100%+)
Where do guys buy the cut gears from?
offroad dude is offline
Old 03-11-2020, 01:21 PM
  #1690
Unless Iím mistaken, you just use the ones that come stock in the SR 5.0 kit.
Old 03-11-2020, 01:42 PM
  #1691
Ok thanks. The 22 5.0 Elite is my 1st 2wd Losi car,
Old 03-11-2020, 01:43 PM
  #1692
thirtydaZe's Avatar
Trader Rating: 38 (100%+)
Did RC Speed Secrets quit doing theirs?
thirtydaZe is offline
Old 03-11-2020, 11:16 PM
  #1693
wisconsinbasher's Avatar
So I am going to be giving an elite a try and I have a bunch of associated front and rear offset mounted tires is there any thing I can do to be able to still use them...
wisconsinbasher is offline
Old 03-12-2020, 12:16 AM
  #1694
front's no
Rears, all you need is a wheel spacer .75mm wider.
jlett21 is offline
Old 03-12-2020, 08:28 PM
  #1695
Hello i just picked up one of these kits.
Is the gear diff offered for this plastic? Will there be a metal option? Will the older gear diff work in the 5.0 elite case?
Thanks guys
Frazaoerik is offline
