TLR 22 5.0
#1651
So decided on a Sanwa m12 RS. As far as the Schumacher setup, they are the cactus and cut staggers.
As far as the track, I can’t post urls yet, but search AJC hobbies.
So far the build is going well. Pretty straight forward. I like how everything for one section of the build is in one bag. One thing I’m going to be redoing are the front control arms. The left one seems to have some bind when inserting the pin through the arm. Its not binding at all just didn’t go in as smooth as the right side.
#1653
so anyone running the ac kit or thinking about it will be SOL and have to look at setup recommendations from a year ago. i currently run the ac kit and i am very happy with it, i will not go down the yellow brick road again like i did with converting the kit 3.0 to a laydown setup and have a shitty car.
#1655
#1656
#1657
I ran my 22 5.0 SR for the first time and was having a lot of issues with the car wanting to push and not turn. Changing from AKA chain links to Pro Line Inversion tires seemed to help, but the issue was still there. Wondering if adding the brass electronics mounting plate would help with front end bite? I'm running the box setup at the moment, so any setup changes are welcomed.
#1658
#1659
#1660
Thank you boh. I didn't know there was a brass kick angle shim. I might give that a try first to put more weight over the from wheels.
#1661
#1662
I would say corner entry. Sometimes if I hit the blue groove just right I'll get better steering action.
#1663
What are you running for front camber and toe?
If you like the way the car drives otherwise I wouldn't add weight. The car will jump and land differently, and accelerate more slowly because it is heavier.
#1664
I'll have to check my ESC settings. I can't recall what drag brake is setup as. Front camber and toe should be whatever the box setup is (turn buckles where setup per the manual). The car definitely jumps very well and I can definitely fell how much slower the 17.5 buggy feels to my Xray mod so I was Leary about adding weight to it but if I'm losing a lot of speed in the corners.
#1665
