Like Tree809Likes
TLR 22 5.0
Old 02-14-2020, 08:19 AM
  #1606
TurnNBurn's Avatar
Originally Posted by bonzo915
To be honest on a 2wd once you build a ball diff unless your a pro your not going to need to access it for months anyway once properly built. And when you do need to do maintenance on it well it's good to take everything out anyway so you can check and make sure everything else is good. I am an average Joe driver so only every couple of months I rebuild my diffs. If there smooth not gritty and car is working properly why do you need to keep replacing them. It's not like a 22-4 to get out diffs anyway, 5 minutes about 10 screws and it's out. All part of the hobby. JMO
If you only drive on tracks that require a ball diff, that’s a fair argument - but if you’re a traveling racer, or someone who races on surfaces requiring the gear diff, then I’d say the feature is appreciated. There’s a reason pretty much everyone else has adopted the feature. The difference between 5-10 minutes and 1-3 is the amount of time you could be on the track testing your Setup changes on practice day.
TurnNBurn is offline
Old 02-14-2020, 09:52 AM
  #1607
Trader Rating: 52 (100%+)
Amen, no way anyone can justify not having this option. Quick access has been making its way into every car and I'm sure TLR is listening.
mx836 likes this.
GettinLapped is offline
Old 02-14-2020, 04:49 PM
  #1608
absolutely in my local area we run carpet and then there is loose dirt and high bite clay and everything in between all in the same race series. Literally no reason at this point to not have it. Such an easy option to implement.
ChadoSan is offline
Old 02-14-2020, 10:29 PM
  #1609
Johnoly99's Avatar
Originally Posted by Phugazi
I've had to use the wider hex to run some DE wheels I had on my 4.0/5.0 buggy so they didn't wobble when bolted up.
19 screws/nuts not counting your slipper, but does include removing the lower shock nuts. And popping off one bulk up. After building and driving A B74 I am really digging the quick access Differentials.
Johnoly99 is offline
Old 02-16-2020, 12:47 PM
  #1610
strodedawg's Avatar
Trader Rating: 81 (100%+)
Ran my AC today at the track on practice day and I love it. Just needs some more tweaking. Love me some TLR
strodedawg is offline
Old 02-16-2020, 01:50 PM
  #1611
TurnNBurn's Avatar
I can’t wait to drive mine. I just need to batten down the wiring, glue the tires I plan on using, and just throw a rattle can job on the kit body - I had commissioned a painter, but my order got delayed by the 22X-4, since I commissioned the two bodies together.
Old 02-17-2020, 12:53 PM
  #1612
Trader Rating: 166 (100%+)
Don’t know If this has been mentioned before. I took my 22 5.0 out with all of the elite updates minus the new steel diff which is backordered until April. Has anyone successfully run 2 gear 7k with the composite diff gears? I’m asking because I need more rotation coming from the rear of the car. I run on a smallish super high grip grey Home Depot grey carpet. 4 gear was done but a tad bit lazy in rotating.
jpcopeland1 is offline
Old 02-18-2020, 04:53 AM
  #1613
Johnoly99's Avatar
if you want more rear rotation, make sure you have the short shock eyes on the rear, and remove the front sway bar. With the short shock eyes it can let the inside tire lift a little more when your heart around the corner, and removing the front sway bar lets the rear end roll quite a bit to transfer that weight to the outside tire letting it rotate
Old 02-18-2020, 01:53 PM
  #1614
Trader Rating: 63 (100%+)
I had one of the small gears shatter into 5 pieces and the t bar break running 2 gear with 20k after a couple race days
The Wease is offline
Old 02-18-2020, 03:03 PM
  #1615
Super Moderator
Kraig's Avatar
If the above suggestions don't help, have your tried running lighter oil? Just a thought.
Kraig is offline
Old 02-18-2020, 08:23 PM
  #1616
Moving the rear hub to the rear will usually free up the rear end
ChadoSan is offline
Old 02-19-2020, 06:21 AM
  #1617
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i am running that diff on my foam tire car i run 5k, 4 gears...that seems best for my application, grey ozite, small tight track...i dont think i would run it with 2 gears.
Matt M. is offline
Old 02-19-2020, 06:14 PM
  #1618
Pretty sure Frank said don't run two-gear with plastic gears. Two-gear with steel diff gears only. Run thinner oil and stick with 4 gears.
Banshee8530 is offline
Old 02-19-2020, 07:27 PM
  #1619
If you run the 22X-4 rear axle/bone it will free the back of the car up.
Chris Reilly is offline
Old 02-19-2020, 10:09 PM
  #1620
Johnoly99's Avatar
??? The parts for the 22x-4 let alone the car isn’t even shipping yet? What do you mean?
