Like Tree881Likes
TLR 22 5.0
Old 01-27-2020, 01:31 PM
  #1516
Trader Rating: 30 (100%+)
I'm a little confused as to which brass c-block I need, I have a 22 5.0 DC its not the elite but I see two part numbers. 334065 or 334053? What is the difference between the two?
Jay13 is offline
Old 01-27-2020, 02:19 PM
  #1517
TurnNBurn's Avatar
053 is the one you want for a regular 5.0. The difference between the blocks is that the new, Elite version uses square pills instead of the oval ones. It allows for .5 and 1 degree changes in 8 different directions, with the center position giving you 3 deg. Toe-in and 2 deg. Anti-squat.
TurnNBurn is offline
Old 01-27-2020, 03:45 PM
  #1518
Thank you, got it ordered.
TurnNBurn likes this.
Jay13 is offline
Old 01-27-2020, 03:48 PM
  #1519
When running a mod (9.5t) motor do you guys run a fan or not? I'm used to rear motor so fans are new to me, other than my B6.1D with a 17.5. I know adding timing makes it hotter but if you keep it in the stock position on a mod should I still run a fan or is it a waste of time?
Jay13 is offline
Old 01-27-2020, 05:18 PM
  #1520
Eli
Eli's Avatar
Trader Rating: 15 (100%+)
Depending on your gearing and how much load your motor is being placed under will dictate motor temps. (load being track conditions, a wet slicks track will create a lot more heat than a low grip pin track in my findings) You will need to make that judgement on motor temps as a motor running too hot will most likely not have the same feel in power towards the end of the run or worse, lose its smoke aka burn up.
Personally, I prefer not to run a fan with a 7.5 unless I absolutely need to. I actually, believe it or not, feel the car handles better without a motor fan on it.
Eli is offline
Old 01-28-2020, 06:09 AM
  #1521
Anyone know if you can just get the Direct Drive top shaft by itself or can you only get it from the Direct Drive kit?
I found this part number TLR232082, looks like it is the correct part...can anyone confirm?
Phugazi is offline
Old 01-28-2020, 06:35 AM
  #1522
You need this one: TLR332044
https://www.amainhobbies.com/team-lo...332044/p495517
jmitchell is offline
Old 01-28-2020, 11:40 AM
  #1523
Originally Posted by jmitchell
Great, thank you!
Phugazi is offline
Old 01-28-2020, 02:25 PM
  #1524
Hey frank I was wondering will there be a AC elite kit that will be coming out ?
Emery1 is offline
Old 01-28-2020, 02:33 PM
  #1525
Trader Rating: 31 (100%+)
Id love to know this as well.
Hopper99 is offline
Old 01-28-2020, 02:47 PM
  #1526
Trader Rating: 28 (100%+)
Anybody know the proper shimming for a tekin t180 servo?
dbracn is offline
Old 01-28-2020, 03:09 PM
  #1527
RazorRC's Avatar
I think the shimming is meant to get the draglink perfectly straight left/right. So whatever you need for that, I run my Savox 1258TG without shims, even though I think the manual says to shim Savox servos.
RazorRC is offline
Old 01-28-2020, 05:08 PM
  #1528
fifi's Avatar
Is jconcept 2547 the correct part number to have the aluminum front wing support that work for the 22 5.0.
fifi is offline
Old 01-28-2020, 05:38 PM
  #1529
Thats not made from aluminum.
Old 01-29-2020, 02:17 AM
  #1530
Any sr owners upgrade their bell cranks and servo mount to aluminum ones? Wondering what the difference would be in feel
Trlmatt is offline
