More caps = better brakes?? >
Like Tree1Likes
  • 1 Post By anr211
Old 11-08-2018, 11:04 AM
Default More caps = better brakes??
I have looked at a bunch of posts but came out wondering if adding more caps will boost an esc's braking power.
If not then is there an esc with strong brakes for around $100 or less? I use HW just stocks and turnigy trackstar 80a.
kenmtb is offline
Old 11-08-2018, 01:02 PM
Turn the reverse strength up on your hobbywing speed control and you might get better brakes. The older hobbywing firmware had braking and reverse tied together for some reason.
mushroomed likes this.
anr211 is offline
Old 11-20-2018, 07:53 AM
Trader Rating: 76 (100%+)
High Torque rotor in your motor makes better brakes
btrukr is offline
Old 11-20-2018, 09:44 AM
brakes ... are the speed controller shorting the winding's of the motor....so more brakes is a different motor, or stator...
or a more powerful speed controller.. to get a near Zero resistance on the motor winding's.
my opinion.
chuck_thehammer is offline
Old 11-20-2018, 07:28 PM
Lineman26's Avatar
Also the bigger pinion gear you are running then the less powerful your brakes will be. Going down a tooth or two will cause your breaking strength to go up.
Lineman26 is offline
