any recomendations for "true" spinning stadium truck wheels?
I have always used DE wheels in short-course and no complaints at all with being true spinning out of the package, perfection. I just spent 60 dollars on a full set of stadium truck wheel and tires(complete) and the wheels are warped like crazy. I know the stadium truck wheel is a different design than sc wheels . Any recomendations on true spinning wheels? I figured they all should be .lol . just not ready to spend more money on another set of warped wheels. Any brands to stay away from?
there is true .. and there is "TRUE"... its not that easy to get "True" wheels in the full size car world...
heat or machine them to your "TRUE".. I have for years..
I mount my wheels to my wood lathe... wood working tools work well on plastic.. set machine to SLOW.
you should see how out of true a $ 150 car wheel is... and we are playing with toy cars... I have $1200 in a 10th scale dirt truck.
Sorry, I can NOT offer any help... maybe someone will chime in that is Helpful...
It has been a while since I last used DE Racing wheels IIRC because they did not spin as true as the original Kyosho wheels on my RT 6. I've used the JConcepts Mono happily ever after on my veteran T4, XT2 and now the YZ-2T. In some cases, it may be the insert's or the tire's fault, though. Make sure there is no excess material left and maybe check and rotate them on the wheel before gluing them and thoroughly check that the insert is where it is supposed to be.
Are you using premounts or did you glue them yourself? If you glued them yourself, are you sure it's not the glue job? In any case list the wheels you are using if they are not spinning true, so others can stay away (thus answering your own question for others).
false alarm guys and girls . Looks like it is user error(my fault) and not the wheels. I just pulled them back out to see if I could figure out what the issue is. When I put them on the balancer the wheels have a significant wobble side to side, like warped. I installed them on the car and there is no wobble and the wheels spin true. Its has something to do with the balancing adapters and not the wheel. DE seems to still be ok in my book,lol. Again , seems to be my fault and not the wheels.
