Yokomo  YZ-2T 2WD ST truck >
Like Tree119Likes
    Hide Wikipost
Old 11-05-2018, 08:42 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2T 2WD ST truck
Last edit by: Cain
Yokomo YZ-2T details to include setup
3 Pad Slipper Conversion Parts needed:
  • YOKS4-303OP Slipper Outer Plate
  • YOKS4-303P1 Slipper Pate Disc Plate
  • YOKB2-670C Slipper Pad (need 1 of these)
Stock Spring Measured Rating (By Neal Lewis)
  • Front: 7.17 n/cm 4.10 lb/in 54.5mm length
  • Rear: 3.77 n/cm 2.15 lb/in 72mm length
Print Wikipost
Old 04-28-2023, 10:44 AM
  #331
Tech Legend
Cain's Avatar
Trader Rating: 293 (100%+)
Originally Posted by Rfury
Which Facebook group?
This group:
https://www.facebook.com/groups/1618315631544873/
Cain is offline
Old 04-28-2023, 12:27 PM
  #332
Originally Posted by Cain
Thanks!
Cain likes this.
Rfury is offline
Old 05-22-2023, 03:12 PM
  #333
Originally Posted by Nosnarb
I'm starting to look for one if you decide to sell.
Hey, I have a new kit that I would be willing to part with. I opened it to make sure everything was there. It was missing a body and nothing else. I have 2 bodies for it though now. Hit me up if you are interested.
Nosnarb likes this.
Rfury is offline
Old 06-23-2023, 07:53 AM
  #334
Nosnarb's Avatar
I saw a FB post regarding running the buggy shocks and shock towers on the YZ-2T on indoor carpet. Anyone doing that and if so what has been your experience with that configuration? I wouldn't think the front shocks would have enough travel for the long a-arms but maybe I'm wrong?
Nosnarb is offline
Old 09-14-2023, 08:24 AM
  #335
Nosnarb's Avatar
maybe I should ask this in the T6.2 forum? I wonder if there is a way to update the YZ-2T set up sheet so that it reflects the updated parts from YZ-4 T6 etc.
Nosnarb is offline
Old 09-14-2023, 11:02 AM
  #336
Tech Legend
Cain's Avatar
funny I actually asked an AE guy who did that on his truck how what he did. h mentioned it wa spretty much bolting on buggy rear shocks and rear tower and then he said he drilled a spot on the a-arm about 11mm in on the inner most shock mount hole from what ir ecal.
As for YZ2T setup sheet, the guy who maintains the sheets on petitrc could probably be contacted to do some updates.
I still got mine sitting here that i need to put together that has the various updates that would be cool in a "TO 2.0" or whatever lol
Cain is offline
Old 09-14-2023, 11:19 AM
  #337
warracer's Avatar
Im doing the setup of my YZ2T for the 23-24' season, I have some T6.2 arms laying around, the main issue is the hinge pins, both are bigger and Im not sure how you'd adapt the front hinge pin inner block.
Also, the C-hub hinge pin inserts hole is too small for the T6.2 outer hinge pins (maybe CAL3/ SO are bigger ?) I'll test later with some parts I have for my yz2 cal3.
But in terms of length and position it looks perfect.
I have a bunch of spare arms and parts so its not too bad for now, but Im mostly interested in running a gullwing arm setup.
warracer is offline
Old 09-14-2023, 11:31 AM
  #338
Nosnarb's Avatar
Did the AE guy indicate any benefits to the change? I'm debating trying it on my YZ2T but don't really have much of an idea on what I am shooting for
Nosnarb is offline
Old 09-14-2023, 11:49 AM
  #339
Tech Legend
Cain's Avatar
Sounds like it lowered the CG, so was able to get in and out of turns faster on high traction stuff. I have wondered to try it with the long 13mm yokomo shocks and a buggy tower on the rear.
Nosnarb likes this.
Cain is offline
Old 09-15-2023, 06:59 AM
  #340
warracer's Avatar
If anyone has tips on how to increase traction on this truck, Im running on clay Jconcept Silver ellipse and last year I couldn't get the truck to hook, steering was really twitchy too...
Found out it has the aluminum carpet steering, so that might not help... I have the dirt rack on order and also the rear pills since they didn't come with the truck.
Also thought about trying the LC transmission case since I really like the way my YZ2 CAL3 worked with it on dirt.
Running kit springs, basically Mayfield CRCRC setup. But this year I'll have to switch it up because it didn't really work.
petersen114 likes this.
warracer is offline
Old 09-15-2023, 07:49 AM
  #341
Nosnarb's Avatar
there are a few clay setups for the YZ2T here https://site.petitrc.com/setup/yokomo/setupyz2t/
I'm not much help as I haven't run on clay. The YZ2T that I picked up was set up for clay and had the LC tranny in it.
warracer and MonkeyCmonkeyDo like this.
Nosnarb is offline
Old 09-15-2023, 09:19 AM
  #342
Nosnarb's Avatar
Anything I missed?
lexusbest and MonkeyCmonkeyDo like this.
Nosnarb is offline
Old 09-15-2023, 10:14 AM
  #343
warracer's Avatar
This is lovely , a part list to do the conversion would be awesome.
Maybe add the option for the CAL3 / DTM3 steering ? I know some guys drilled the chassis and the last chassis came pre drilled for it
Nosnarb likes this.
warracer is offline
Old 09-15-2023, 10:27 AM
  #344
Nosnarb's Avatar
yeah looks like I missed the steering rack
Nosnarb is offline
Old 09-15-2023, 02:56 PM
  #345
lexusbest's Avatar
Wow! You nailed it!
lexusbest is offline
