Yokomo  YZ-2T 2WD ST truck >
Like Tree99Likes
    Hide Wikipost
Old 11-05-2018, 08:42 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2T 2WD ST truck
Last edit by: Cain
Yokomo YZ-2T details to include setup
3 Pad Slipper Conversion Parts needed:
  • YOKS4-303OP Slipper Outer Plate
  • YOKS4-303P1 Slipper Pate Disc Plate
  • YOKB2-670C Slipper Pad (need 1 of these)
Stock Spring Measured Rating (By Neal Lewis)
  • Front: 7.17 n/cm 4.10 lb/in 54.5mm length
  • Rear: 3.77 n/cm 2.15 lb/in 72mm length
Print Wikipost
Old 10-10-2022, 01:32 PM
  #301
psycho02's Avatar
Trader Rating: 14 (100%+)
Kind of what I thought but was not familiar with yokomo and thats the first sight a search came up with.
psycho02 is offline
Old 10-10-2022, 01:51 PM
  #302
Originally Posted by Cain
Looks like some place registered out of china back in 8-25-22, and it right away comes up with a secured virus by my virus scanning software.
I hope it is bogus, which I'm sure it is. If those were actual prices from Yokomo it would mean they're having it going out of business sale and nobody wants that
Milkdudd is offline
Old 10-11-2022, 05:10 AM
  #303
Tech Legend
Cain's Avatar
Trader Rating: 293 (100%+)
Yeah be curious see what is what, but I recall something kind of like this site before and it was basically like a cash grab.
Cain is offline
Old 12-12-2022, 01:56 AM
  #304
strodedawg's Avatar
Trader Rating: 81 (100%+)
where can i find 13.5 carpet set ups to start with for this truck? need a starting point TIA
strodedawg is offline
Old 12-12-2022, 05:32 AM
  #305
Tech Legend
Cain's Avatar
That setup I posted I used on carpet with a 13.5 as well as our higher traction turf track (its more like a carpet). It may give you a good starting point to at least try.
petitrc also has a variety of YZ2T setups to start with, mine was based on that.
Cain is offline
Old 01-23-2023, 09:46 PM
  #306
When are we getting an update on this truck now that the new 2wd and 4wd buggies are released
zzztech is offline
Old 01-24-2023, 04:47 AM
  #307
Tech Legend
Cain's Avatar
Haven't heard anything, I am hopeful that if they do continue on doing the truck that its an actual update with the new materials and parts and not a "TO 1.0" that is just the current YZ2T with some aluminum bits added, revising the a-arms to use the thicker hingepins the other vehicle use would be great.
Cain is offline
Old 01-27-2023, 02:08 AM
  #308
At this stage I’ll be happy with anything to complete my collection lol
zzztech is offline
Old 01-27-2023, 05:45 AM
  #309
Tech Legend
Cain's Avatar
Unfortunately I have heard that no new truck is being made and they they are discontinuing this YZ2T completely
Cain is offline
Old 02-27-2023, 09:39 AM
  #310
Rfury's Avatar
I am looking for a YZ-2T to complete the Yokomo 10th scale set. I have a CAL3, DTM3 and a YZ-4 SF2. I can't find a truck used or new right now. I thought about buying the parts and a DTM3 as a donor and converting it. Unfortunately, the rear shock body is unobtanium in North America and I have only seen some in Europe, Asia and Australia/New Zealand.
Rfury is offline
Old 02-27-2023, 10:09 AM
  #311
Tech Legend
Cain's Avatar
As an option, you could see about doing the 13mm shocks from AE on the car. Testing out the buggy variants here on my CAL3.1 and getting them where I want.
Cain is offline
Old 02-27-2023, 11:16 AM
  #312
Rfury's Avatar
I did consider that as well. The AE shocks are a bit pricey though.
Rfury is offline
Old 03-02-2023, 08:42 PM
  #313
Does the truck uses a cal3.1 chassis? Thinking of building my own
zzztech is offline
Old 03-03-2023, 07:55 AM
  #314
Tech Legend
Cain's Avatar
No it uses its own truck chassis.
Cool thing from what i am reading and there is one up on the for sale section now, you can rig up associated a-arms it appears with a simple swap, and I think you go to the larger 3.5mm hingepin pills and hingepins on the rear.
Could then run with it and update to yz4sf2 hub carriers if you want for more tuning options.
zzztech and Nosnarb like this.
Cain is offline
Old 04-17-2023, 01:13 PM
  #315
Another option is the 13mm Avid shock bodies for TLR G3 shocks. I think if you add up all of the parts it's as much if not more than the AE route. I Wish Avid would make 13mm bodies for yokomo shocks.
https://www.avidrc.com/product/5/acc...cessories.html
Nosnarb is offline
