Yokomo  YZ-2T 2WD ST truck >
Like Tree119Likes
    Hide Wikipost
Old 11-05-2018, 08:42 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2T 2WD ST truck
Last edit by: Cain
Yokomo YZ-2T details to include setup
3 Pad Slipper Conversion Parts needed:
  • YOKS4-303OP Slipper Outer Plate
  • YOKS4-303P1 Slipper Pate Disc Plate
  • YOKB2-670C Slipper Pad (need 1 of these)
Stock Spring Measured Rating (By Neal Lewis)
  • Front: 7.17 n/cm 4.10 lb/in 54.5mm length
  • Rear: 3.77 n/cm 2.15 lb/in 72mm length
Print Wikipost
Old 09-03-2021, 01:45 PM
  #286
petersen114's Avatar
Originally Posted by edsevenrage
Mine should show up today. Set up for carpet. Never raced a day in my life so this will be interesting. Can't wait
Great trucks.
edsevenrage likes this.
petersen114 is offline
Old 09-03-2021, 09:52 PM
  #287
Sadly it came with a broken rear hub. Missing screws and other problems but I sorted it out. Quality is beautiful. First yokomo I've ever owned. I'm impressed. Also a very cool design
petersen114 likes this.
edsevenrage is offline
Old 09-05-2021, 12:28 PM
  #288
Curious to know what idler gear to use with the lc trans case. I have a cal 43 tooth idle gear. Would that be the one?
Old 09-05-2021, 02:33 PM
  #289
Will27's Avatar
Yes. There are only 2 idlers:
Z2-503I - small idler for LD, standup, 4 gear laydown
Z2-503IC - large idler for 3 gear laydown, including LC
Will27 is offline
Old 09-05-2021, 02:44 PM
  #290
Awesome. Thanks
Old 09-24-2021, 01:41 AM
  #291
Hi everybody,
I'm buliding a YZ2-t right now and I came to a point where I stumbled.
When building the front c-hubs, the caster inserts "YZ-413" don't fit the pin "B2-009AF". The inserts have 3mm diameter and the pin only 2.5mm. The pin fits the arms nicely, so to me the caster inserts have a wrong diameter.
Therefore the c-hub is really loose, that can't be right.
Am I missing something or has anybody encountered the same problem?
Thanks for any help.
Andi
andreas78 is offline
Old 09-24-2021, 03:04 PM
  #292
Will27's Avatar
Originally Posted by andreas78
Hi everybody,
Andi
Sounds like you have received the wrong caster block set. The CAL3/DTM3 use a 3mm hinge pin, so the caster block set Z2-413DC has 3mm holes in the inserts. The truck still uses the earlier 2.5mm hinge pin and should have the caster block set from the CAL2/DTM/DTM2 with 2.5mm holes, Z2-413DM.
andreas78 and DirkW like this.
Will27 is offline
Old 09-25-2021, 04:13 PM
  #293
Thanks, I studied the manuals of all the different YZ vehicles and you're right. Still wondering how that could happen, it was a originally sealed box from a trustworthy seller. I contacted him about the issue.
Andi
Will27 likes this.
Old 09-26-2021, 05:51 AM
  #294
I would go w/ the carbon battery hold-down like the one I have on my truck or at least the rubber band type hold-down if you haven't already did this.
Old 09-26-2022, 12:09 PM
  #295
Tech Legend
Cain's Avatar
Trader Rating: 293 (100%+)
for those still running the truck, this last setup from our outdoor turf (that is the grizzly grass stuff which is a bit higher bite) has worked pretty well as a starting point:
Nosnarb likes this.
Cain is offline
Old 10-09-2022, 09:52 AM
  #296
Trader Rating: 25 (100%+)
Anyone have any good suggestions on Servo's for the YZ2T? I've always used Savox, however I'm not any particular brand fanboy.
If it helps I run Futaba radios.
SwampDog32 is offline
Old 10-10-2022, 06:28 AM
  #297
Tech Legend
Cain's Avatar
I'd say a standard size servo with spec similar to the Tekin T-250 would work well. I think Protak has a 155T that works well too
SwampDog32 likes this.
Cain is offline
Old 10-10-2022, 01:02 PM
  #298
psycho02's Avatar
Trader Rating: 14 (100%+)
Looking at this yokomo-shop website this has to be a scam. These prices cannot be real or are they just liquidating?
Yokomo-shop.com, Buy cheap and hot online Yokomo YZ-2T 1/10 2WD Electric Stadium Truck Kit in Yokomo Sales Store
psycho02 is offline
Old 10-10-2022, 01:18 PM
  #299
Will27's Avatar
The URL from the yokomo website for their webshop is: shop.teamyokomo.com, so I'd guess that site is dodgy.
Will27 is offline
Old 10-10-2022, 01:19 PM
  #300
Tech Legend
Cain's Avatar
Looks like some place registered out of china back in 8-25-22, and it right away comes up with a secured virus by my virus scanning software.
Cain is offline
