Yokomo YZ-2T 2WD ST truck
#271
#275
I'm running a Highest DLP750 in mine.
#277
What gain is achieved by using the vented outer slipper plate?
#280
It's been a while since we sold our YZ2Ts, but when the grip is up, try 1.4/1.1. I moved tge shocks behind the rear shock tower also on carpet because it was a handfull. 1.8 pistons in the rear were also a step forward for my son's truck, which was the one we kept longer.
#281
What did moving the shocks do for by moving to the rear? More or less traction?
#282
So got a another short session in with my yz2t on carpet. Using basically Shin's setup from petitrc but with a 17.5 motor as its what I had on hand. I also use the schelle slipper setup as that is what I prefer.
This setup with the tires I was using offers almost too much rotation for my liking. so i wonder a bit on taking some of that out before breaking a CVD axle. Second time that happened here as the pin that holds the bone to the axle came loose and jammed up things. The C-clip I am thinking is bad so I am going to try something else and some shrink wrap to help. This is using the 87mm bones.
Outside of that the truck is good. Just need to keep her together for actual races lol.
#284
