Yokomo  YZ-2T 2WD ST truck >
Like Tree170Likes
    Hide Wikipost
Old 11-05-2018, 08:42 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2T 2WD ST truck
Last edit by: Cain
Yokomo YZ-2T details to include setup
3 Pad Slipper Conversion Parts needed:
  • YOKS4-303OP Slipper Outer Plate
  • YOKS4-303P1 Slipper Pate Disc Plate
  • YOKB2-670C Slipper Pad (need 1 of these)
Stock Spring Measured Rating (By Neal Lewis)
  • Front: 7.17 n/cm 4.10 lb/in 54.5mm length
  • Rear: 3.77 n/cm 2.15 lb/in 72mm length
Print Wikipost
Old 11-01-2019, 11:18 PM
  #211
mes
Originally Posted by slider3
Just pick up a new Yz2T and looking forward putting it on the track. I just have the shock springs that came in the kit. Sounds like the AE springs are the ones to run. Does anyone have some part numbers on what springs I will need. I'm listening if there is another option for springs. I appreciate the information in advance.
Yokomo meanwhile released a couple of springs specifically for 4WD and truck.
https://www.redrc.net/2019/06/yokomo-introduce-new-racing-performer-off-road-springs/
AE V2 are very good, but it is hard to judge your requirements without knowing your track. My advice would be to check out the set-up sheets for the YZ-2T and/or the T6.1 for your track or similar ones. IIRC my son has used orange fronts and yellow rears on carpet and astro most of the time, sometimes switching to red fronts and grey rears.
dikke hond likes this.
mes is offline
Old 11-03-2019, 04:58 AM
  #212
Trader Rating: 119 (100%+)
https://www.redrc.net/2019/06/yokomo...-road-springs/
Mes, Thanks for the response. Our track is on the small side and tight, gray carpet. So the AE springs your son using are off the SC6.1. The colors you mention on the spring match up. Plus you have to use the AE 9mm tall spring cups? Is this correct? Why canít you use the 6.1? You can get those in the same length and rate as the YZ2T stock springs? Just different colors on the springs.
slider3 is offline
Old 11-03-2019, 05:13 AM
  #213
mes
The springs are the buggy springs released with the B6.1, ie. L44 front and L61 rear. We've been using the stock spring cups and not encountered any issues.
mes is offline
Old 01-21-2020, 01:26 PM
  #214
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
so anything new with the truck?
Cain is offline
Old 01-30-2020, 08:20 AM
  #215
Tech Legend
Cain's Avatar
so noticed something interesting when looking at parts. appears a-amain isn't stocking the yz2t rear shock shafts? Anyone know offhand if the shafts on the rear are longer than say buggy shafts?
Cain is offline
Old 02-07-2020, 03:13 AM
  #216
purplemonkey's Avatar
Ya shock shafts and shock bodies , YOKZ2-S4RT, is discontinued.
purplemonkey is offline
Old 02-08-2020, 06:52 AM
  #217
Trader Rating: 51 (100%+)
What's a good pinion to start with using an 8.5T?
Apex is offline
Old 02-08-2020, 12:47 PM
  #218
I'm far from being the expert so keep that in mind, but I just went from a 23 to a 25 tooth with a 10.5T motor running on a clay track. I finally have enough top speed to clear a 23-foot triple. Next week I plan to put a brand new 8.5T motor in it and will start with the same 25 tooth I have in it now. Can let you know after that how it goes.
Apex likes this.
Milkdudd is offline
Old 02-11-2020, 07:52 AM
  #219
Tech Legend
Cain's Avatar
If I was using say the Tekin Gen3 motors with reasonable timing, I'd probably start with an FDR of 9.5 or so and see how it felt and temped around the track.
For the shaft discontinued issue this is being corrected as they shoudl not have been.
Cain is offline
Old 02-11-2020, 09:47 AM
  #220
I am in the process of building a YZ4SF conversion to 4WD truck. I need the stroke length of the truck rear shocks. I was going to use Associated but not sure if they will work. Factory Foote are busy I guess an not responding to emails right now on another subject. Thanks in advance if someone can get me the info.
Old 02-11-2020, 10:40 AM
  #221
Tech Legend
Cain's Avatar
I'll see about checking today for you on that. I run the shocks with no limiters and the longest eyelets to get the most droop out of them.
purplemonkey likes this.
Cain is offline
Old 02-11-2020, 11:06 AM
  #222
COOL. THANKS
Old 02-11-2020, 08:45 PM
  #223
Tech Legend
Cain's Avatar
left calipers at a buddy, will get measurement tomorrow.
Hoping to get my truck together tomorrow give it a maiden to me run thursday
Cain is offline
Old 02-11-2020, 11:32 PM
  #224
Default Lil Something in the works.
little something me and another teammate have been working on.
Nosnarb likes this.
GETDAT is offline
Old 02-13-2020, 09:58 AM
  #225
Tech Legend
Cain's Avatar
that part that the shock end is mounted to on the a-arm, what is that? I wouldnt mind that but in reverse for my yz4sft to get more effective droop on the rear end!
Cain is offline
