Yokomo  YZ-2T 2WD ST truck >
Like Tree170Likes
    Hide Wikipost
Old 11-05-2018, 08:42 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2T 2WD ST truck
Last edit by: Cain
Yokomo YZ-2T details to include setup
3 Pad Slipper Conversion Parts needed:
  • YOKS4-303OP Slipper Outer Plate
  • YOKS4-303P1 Slipper Pate Disc Plate
  • YOKB2-670C Slipper Pad (need 1 of these)
Stock Spring Measured Rating (By Neal Lewis)
  • Front: 7.17 n/cm 4.10 lb/in 54.5mm length
  • Rear: 3.77 n/cm 2.15 lb/in 72mm length
Print Wikipost
Old 09-28-2019, 08:11 PM
  #196
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
I have a crazy question, there is a nice little machined out area under the motor, is there a weight made to slip in there? Thanks!
thecman26 is offline
Old 09-29-2019, 08:10 AM
  #197
Trader Rating: 53 (100%+)
Not that I have seen yet.
GettinLapped is offline
Old 09-29-2019, 02:53 PM
  #198
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Messages Charles foote from foote factory. He may be able to make something as he has something for the buggies.
Cain is offline
Old 09-29-2019, 06:33 PM
  #199
Trader Rating: 166 (100%+)
I have a simple question for the group.
Are there any bodies available beside the "stock" JConcepts body that is kind of hard to find in stock?
Something that will fit and NOT look like a turd that is!
22T 4.0 finisher fits. Need to change hole locations.
thecman26 likes this.
jpcopeland1 is offline
Old 09-29-2019, 11:11 PM
  #200
thecman26's Avatar
Cool.
Old 10-10-2019, 05:37 PM
  #201
Cool.
it is insanely better on both dirt and carpet/
Old 10-10-2019, 05:40 PM
  #202
Originally Posted by mes
Bodies are cross compatible with the T6.1 and Xray XT2 '19.I just bought an Xray body for my son's truck, but I am looking forward to the JConcepts Finnisher the team used at the ROAR nationals.
the 22T 4.0 actually works better on carpet. Less front downright downforce keeps the front end flatter. But both are a huge improvement over the ice cream truck body.
mes likes this.
Old 10-10-2019, 07:35 PM
  #203
thecman26's Avatar
I will give mine a go this weekend!
Old 10-17-2019, 09:43 AM
  #204
You wont regret it, just having the front end not dive off power in turns is huge.
Old 10-23-2019, 05:11 PM
  #205
Trader Rating: 119 (100%+)
Default YZ-2T Questions
Our track has switch over to carpet and i'm looking for a stadium truck. The track hobby shop supports the Yokomo, parts on hand. He has presented me with a good deal on the truck. I have always ran TLR and Associated. I don't know much about the Yokomo. I appreciate any feedback you can give on the truck.
The +s and -s of the truck?
How durable are they?
What extra parts or upgrades do I need?
What all is needed for the truck to run on carpet except the gear diff?
How does it compare overall with the TLR 22t 4.0, T6.1 and the XT2c.
I appreciate any input.
slider3 is offline
Old 10-24-2019, 09:24 AM
  #206
Tech Legend
Cain's Avatar
shot you a message. in general though for carpet these would be things at a minimum I would do / get:
- 87.5mm dog bones
- gear diff
- do the battery tray extra screw mod
- different springs and spring cups (if needed). I used AE springs and spring cups
That would get you going basically. I also liked the aluminmum ball stud mounts and steering rack personally.
Cain is offline
Old 10-25-2019, 05:01 AM
  #207
thecman26's Avatar
Truck was absolutely amazing, I was not wanting anything! Had plenty of traction and steering! Pretty much box stock except I switched rear shocks to back of arms.
Old 10-26-2019, 09:50 AM
  #208
This is by far my biggest complaint about this truck. The stock body just makes it feel bumbly with weight transfer, especially up front. I'll order a new JC Finnisher body for it and see how that works.
mtbwrench is offline
Old 10-28-2019, 08:17 AM
  #209
mes
The Xray body did little better than the F2 and Enforcer. Again, the front section cracked after some really minor impacts. I begin to wonder wether there is an issue with the body mount. We'll give the Finnisher a try when it is available in Germany and reinforce the nose with ShoeGoo from the start. If this body also cracks after a day of practice, the truck has earned a spot on the shelf, which would be a pity because it felt amazing with the Shin set-up and the shocks in the rear.
mes is offline
Old 11-01-2019, 05:36 PM
  #210
Default AE Shock Springs
Just pick up a new Yz2T and looking forward putting it on the track. I just have the shock springs that came in the kit. Sounds like the AE springs are the ones to run. Does anyone have some part numbers on what springs I will need. I'm listening if there is another option for springs. I appreciate the information in advance.
slider3 is offline
