Yokomo  YZ-2T 2WD ST truck >
Like Tree52Likes
    Hide Wikipost
Old 11-05-2018, 08:42 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2T 2WD ST truck
Last edit by: Cain
Yokomo YZ-2T details to include setup
3 Pad Slipper Conversion Parts needed:
  • YOKS4-303OP Slipper Outer Plate
  • YOKS4-303P1 Slipper Pate Disc Plate
  • YOKB2-670C Slipper Pad (need 1 of these)
Stock Spring Measured Rating (By Neal Lewis)
  • Front: 7.17 n/cm 4.10 lb/in 54.5mm length
  • Rear: 3.77 n/cm 2.15 lb/in 72mm length
Print Wikipost
Old 08-15-2019, 09:05 AM
  #181
Tech Legend
Cain's Avatar
Trader Rating: 259 (100%+)
Originally Posted by indybobb View Post
Truck has the 87.5mm bones, Swagger front tires, battery is to the rear, front ball studs with 2mm. Why would lower diff oil calm it down? wouldn't it rotate even more? have 15k with 4 gears in right now. Will give the shortest links up front a try also ordered the 15.5mm servo horn. Rear hubs are the kit plastic. I haven't found an answer to the difference in handling between the long vs short steering arms that come with the kit. Have the long ones on, will the short ones tame the steering or make it even worst?...
We saw with lighter oil more rear grip relative to the rotation, the rear end didn't want to step out like it was doing hence making it feel more consistent and less twitchy to us at least, since the rear was breaking free too easy.
You are running all 4 gears? In the shin setup it mentions 2 from what I recall, I would go down in oil if sticking with 4 gears then for sure. I think when doing 2 versus 4 gears I seem to recall I was at almost half in oil weight, so 15K gear I would probably do 7K in 4 gear feel wise. You will have to play with that.
As mentioned by mes, negative expo can be an option too (some spektrum radios the opposite value is used to calm it down, don't know why)
One other thing, as for roll centers in comparison to the guide I posted versus what I think the hudy setup books have, there is a discrepency on the effect. I reached out to the creator of the helper sheet about this and he mentioned what they were seeing versus what the hudy book was saying was different. Again, I think its this section in question, which would explain why from what we are seeing by adding in more shims under the front tower ball stud we are seeing a decrease in steering into the corner and the car being less responsive. Good thing is its a quick change to try.
Cain is offline
Old 08-20-2019, 02:48 PM
  #182
Trader Rating: 161 (100%+)
Originally Posted by Cain View Post
AE Wheels work.
Buddy of mine was running Associated before albeit a T5M and he is very fast, he liked how the yokomo's quality is. Car was very fast and durable in his hands.
Get the 87mm bones or whatever they are instead of the 89mm . 89mm stockers bind up against the diff we found when running the diffs risers.
For carpet, the shin setups on petitrc work very well.
you may like the LC tranny to try versus the LD I beleive it comes stock with.
does the lc trans case work without modification? I know it would be missing the front two screws.
jpcopeland1 is offline
Old 08-20-2019, 03:17 PM
  #183
Will27's Avatar
You need the larger idler Z2-503IC and the LC case. Bolts right in, all the holes are there.
Cain likes this.
Will27 is offline
Old 08-20-2019, 03:18 PM
  #184
LOW ET's Avatar
Trader Rating: 103 (100%+)
read in the description : https://www.amainhobbies.com/yokomo-...302tlc/p961510
LOW ET is offline
Old 08-20-2019, 04:39 PM
  #185
yeah, just swapped the case and diff out of my stock cal3. Perfect fit. Should have tried it first before I posted lol..
Old 08-21-2019, 11:47 AM
  #186
Tech Legend
Cain's Avatar
all good worth asking Should add it to the wiki.
Know someone going to have a YZ2T up for sale soon if anyone is looking.
Cain is offline
Old 08-25-2019, 07:06 PM
  #187
R/C Tech Elite Member
bwarn97's Avatar
Trader Rating: 43 (100%+)
Might be interested, PM me details
bwarn97 is offline
Old 08-29-2019, 02:28 AM
  #188
Having a bit of a problem with the ballcups rubbing really badly using jconcepts rims. It seems like the yokomo ballcups are way too thick. Has anyone tried the angled cups? Or is there a thinner 5.5mm cupnout there other then running ae cups on the steering tie rods.
Old 08-29-2019, 08:49 AM
  #189
Tech Legend
Cain's Avatar
pics of issue?
Cain is offline
Old 08-29-2019, 05:24 PM
  #190
pics of issue?
will post up in a minute.
Cain likes this.
Old 08-31-2019, 06:43 PM
  #191
Culley606's Avatar
Default Chassis length and wheelbase?
Wondering if someone could post what the chassis length is and what the axle to axle wheelbase is on the truck?
thank you.
Culley606 is offline
Old 09-14-2019, 04:18 AM
  #192
thecman26's Avatar
I have a simple question for the group.
Are there any bodies available beside the "stock" JConcepts body that is kind of hard to find in stock?
Something that will fit and NOT look like a turd that is!
thecman26 is offline
Old 09-14-2019, 11:43 AM
  #193
mes
Bodies are cross compatible with the T6.1 and Xray XT2 '19.I just bought an Xray body for my son's truck, but I am looking forward to the JConcepts Finnisher the team used at the ROAR nationals.
thecman26 likes this.
mes is online now
Old 09-14-2019, 04:41 PM
  #194
thecman26's Avatar
Super! Thanks!
Old 09-20-2019, 12:06 PM
  #195
Tech Legend
Cain's Avatar
anyone looking for a YZ2T got a buddies one up for sale.
Cain is offline
