Old 02-18-2006, 01:07 PM   #1
Suspended
Default My Pulsar 2 taking 45 mins to charge a 3600 battery? Advice needed please...
I have a Pulsar 2 from LRP and I charge my 3600 pro match batteries 1.20v with it. The problem is they take about 40-45 mins to charge 1 battery. I followed the instructions from pro match and i set my peak detection at 15mv and that was the setting where the batteries reached a temperature of 127F when the peak detection set off. I am charging at 5 amps. Any suggestions or is this normal?
Jhyten is offline   Reply With Quote
Old 02-18-2006, 07:28 PM   #2
I would say it is normal. 3300's take around 30-35 minutes when fully discharged and my ib3800's take around that 45 mark at 6 amps. If time is an issue i pre charge at a lower amp and then peak it off at the track depending on amount of time i have. You sacrifice some voltage but I am not good enough to notice. When i quit crashing then I will worry about that extra voltage.
sjenkins97 is offline   Reply With Quote
Old 02-18-2006, 07:47 PM   #3
its actually better to charge your battery at lower amps even if it takes longer..and the time it's taking sound about right, it used to take me an hour to charge a 3000 mah pack, but thats cuz i had it on like 2.5 amps..just my 2 cents
rally is offline   Reply With Quote
Old 02-18-2006, 08:16 PM   #4
Suspended
Ok thanks guys. As long as that sounds normal i wont worry. Thanks for the input
Old 02-18-2006, 09:38 PM   #5
(Mah/1000)/amps charging at = time in hours
time*60=time in minutes
(3600/1000)/5 = 0.72 hours
0.72*60 = 43.20 minutes
binaryterror is offline   Reply With Quote
Old 02-18-2006, 11:03 PM   #6
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
Yeah what he said.
Tony
RcCzarOfOld is offline   Reply With Quote
Battery and Charger advice needed te04rx8 Rookie Zone 7 04-29-2009 06:29 PM
new battery not taking a full charge?? PorTX Radio and Electronics 2 07-13-2008 11:20 AM
LRP Pulsar 1 setting for Intellect Battery 3600, 3800 and 4200 rcmnx Electric On-Road 12 01-27-2006 05:05 PM
Can I charge my radio (without taking out batteries)? trp7 Rookie Zone 2 12-23-2005 02:18 PM
Pulsar charge TX Battery Neosaka Electric On-Road 8 11-01-2003 04:11 PM
